Door lock not opening.
Old Nov 9, 2007 | 11:25 AM
tac4005's Avatar
tac4005
Default Door lock not opening.
Sometimes when I remove the key from the ignition, the passenger door doesn't unlock automatically. Even pressing the unlock button doesn't work all the time. The key fob sometimes works, other times it doesn't... What to do?
Old Nov 9, 2007 | 11:35 AM
vincentjames501's Avatar
vincentjames501
scroll through the options and i think its called passive unlock. Set to both I believe. Its one of those options.
Old Nov 9, 2007 | 11:45 AM
tac4005's Avatar
tac4005
But sometimes it works no problem, then sometimes it doesn't. But I'll check that out. Thanks.
Old Nov 9, 2007 | 11:55 AM
TEXHAWK0's Avatar
TEXHAWK0
If it only works intermittently from different sources, I would think the door lock actuator was going bad, from moisture, bad connection, etc.
Pull the door panel off and check it out. If the linkage is not binding, I would just replace the actuator.
Old Nov 10, 2007 | 05:55 PM
TNX ZORA's Avatar
TNX ZORA
It sounds like the control relay is going out on you. Lots of repair info available on this since the original relays tend to be flakey.
Old Nov 11, 2007 | 10:48 PM
MrLeadFoot's Avatar
MrLeadFoot
Do a search. Plenty info on replacing the unlock relays. I replaced mine, which exhibited the EXACT same behavior as your is now. Search the archives for my name, and you'll get threads complete with instructions, part numbers, pics, the works. DigiKey sells the relays for $1.35 a piece. Stealership wants $500 to replace the door control module.
To Door lock not opening.
