HID kit interferring with radio reception
Old Nov 9, 2007 | 09:05 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Default HID kit interferring with radio reception
Hi everyone, I just recently installed my HID bulb kit, and of course with every modification I have done to this car, it affects something else. Now my radio reception goes to almost nothing with the lights on. Is anyone else having this problem, and if so, is there an electronics filter, or antenna amp to help with this. I love the lights so if need be I could give two craps about the radio, but I would rather it all work properly.
Thanks for any suggestions,
Chris
Old Nov 10, 2007 | 09:35 AM
SKF engineer's Avatar
SKF engineer
I first read about the HID kits yesterday and I would be very interested to hear if others have had problems with the radio also as I was thinking about one of these kits also.
Old Nov 10, 2007 | 08:12 PM
ILM-Express's Avatar
ILM-Express
MFIC
try moving your ballasts to a lower location
Old Nov 10, 2007 | 10:21 PM
St. Jude Donor '09
I installed them at the very bottom of the inner wheel well liner per the instructions, any lower and they will be on the bottom of the car.
Old Nov 10, 2007 | 10:56 PM
TNX ZORA's Avatar
TNX ZORA
I've been watching these HID installs for several months and this case of RFI is the first I've seen. There may be considerable interest in the cause and cure in your situation. If is is an isolated case and yet your ballasts, etc. are typical then I would think there may be a correctable fault that exists within your particular installation. Other than possibly being caused by a defective ballast about all you can do is check your wiring very carefully, especially the ground connections. Generally, interference-causing wiring is typically treated by shielding it. If any of your ballast wires appear to incorporate shielding be sure the shields are intact and grounded on both ends. What does the seller have to say about this?
Old Nov 10, 2007 | 11:58 PM
Sick Z06's Avatar
Sick Z06
UNplug 1 ballast at a time, and see if you can confirm it is just 1 of them, not both causing the issue. If so, great. You've got a defective ballast that is causing noise, that can be replaced.
Old Nov 11, 2007 | 01:59 AM
Speed Trap's Avatar
Speed Trap
I checked mine out for this problem right after I installed them but found no interference with the radio.
Old Nov 11, 2007 | 10:45 PM
MrLeadFoot's Avatar
MrLeadFoot
I have 6 HID ballasts in my car. I noticed that for stations that come in clear, there is no issue. However, stations that are problematic to begin with have slightly more static than usual with the lights on. But, since I don't like to listen to stations that have marginal reception (read: static) to begin with, it has not posed a problem for me.
FWIW, my ballasts are the nice German-made ballasts, which might be of a different quality than others I've seen on E-Bay.
Old Dec 28, 2007 | 05:32 PM
peebee_c5's Avatar
peebee_c5
Curious to see if you ever found a solution to this (and hoping I have no such problems with my upcoming HID installation).
If you can narrow this down to one bad ballast, your best bet would be to replace the ballast.
If replacment is not an option, you might try installing a "ferrite core" on the offending wiring.... Try to locate the source (left vs. right side) by unplugging each one at a time. Then try installing the ferrite core around the 12V wiring, or around the high-voltage side (feeding the bulb), or putting two cores in, one on each side of the ballast.
But the core would just mask the problem -- which could well be a bad (failing?) ballast....
Old Dec 28, 2007 | 06:37 PM
c5mtl's Avatar
c5mtl
i have 4 ballast and no problems
Old Dec 28, 2007 | 06:58 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
this is the second report i have heard of this.
Maybe you can locate the guy that had the same issue.
Old Dec 30, 2007 | 10:42 PM
pk1's Avatar
pk1
I have a buzzing sound coming through my speakers when I turn on the hids.
Old Dec 31, 2007 | 12:41 AM
Bell's Avatar
Bell
Could you please tell us where you bought your HID's? What color temp rating? I also have been reading lots of posts about HIDs and have not heard of this being a problem yet. I suggest you contact jdmvette for advice. He seems to be very knowlegable about these things.
Old Jan 5, 2008 | 10:50 AM
peebee_c5's Avatar
peebee_c5
Any update on this?
Old Jan 5, 2008 | 11:00 PM
MrLeadFoot's Avatar
MrLeadFoot
IMHO, it's no big deal, because like I posted above, it only affects stations that are already not coming in clearly, which you probably don't listen to anyway. For stations that are coming in clearly, it doesn't affect them at all. It's alot like other electrical interference that the car puts out already. In fact, it's so minor, I didn't even notice it until the Original Poster brought it up.
So, let me put it another way: the little bit of interference is well worth the HID kit. Now, if the ballasts interfered with the clear stations, too, that would be another story, but they don't, so I, for one, would do HIDs again in the future in a heartbeat.
FWIW, I have 6 HID ballasts.
Old Jan 6, 2008 | 01:56 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Shield the power wires that you are connecting to or use a larger gauge ground wire.
Old Jan 6, 2008 | 09:50 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
you could always upgrade to satellite radio........
Old Jan 6, 2008 | 11:07 AM
DT's Avatar
DT
I'm running the ACA kit (which is the complete projectors/housing/HID system) and don't have any radio interference as far as I can tell (I only listen to 2 stations and they're both strong signals).
I mainly listen to CD's and there is definitely not any noise during CD playback.
My ballasts are on the inside of the frame with the tops facing the airfilter.
To HID kit interferring with radio reception
