HELP with engine code
Old Nov 11, 2007 | 11:08 AM
blaplant's Avatar
blaplant
St. Jude Donor '12
Default HELP with engine code
i have been having this code come on once a week sometimes twice for about a month and half now. the code is P0442 how can i figure out where the leak is comming from. it is an emmision leak right? any help with be great. THANKS
Old Nov 11, 2007 | 11:27 AM
jirasvet's Avatar
jirasvet
Make sure your gas cap is being put on right and that you hear it clicking
when putting it on. Easiest first try would be a new gas cap. You may
have a leak at the evap purge solenoid or schrader valve. All this could
be tested if you have access to a bi directional control scan tool.
ie.Tech II.
hope that helps you
Old Nov 11, 2007 | 11:29 AM
blaplant's Avatar
blaplant
St. Jude Donor '12
Thank you very much I'll try that today.
To HELP with engine code
