Guys what the hell is this?
Old Nov 13, 2007 | 08:10 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
That's really class. Wonder what button blows up the ricer?
Old Nov 13, 2007 | 10:58 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Okay I actually built one for craps and giggles for my silverado. Keep in mind i was in high school and completely bored. I used the compression fan from a model aircraft jet engine. While it did absuolutely nothing but make noise, there was somthing crazy-cool about doing it. (it came off after a week of insanity) The Home made CAI box stayed however....and yes that is dryer ducting.
Old Nov 13, 2007 | 06:20 PM
corvettejoe98's Avatar
corvettejoe98
hahahaha wow. its def. a true ricer toy, I would imagine it would drain your battery so much that your car wont start back up hahah funny **** though.
Old Nov 13, 2007 | 08:05 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
It's a good thing i had a optima yellow top and a 180 amp CS144.
Old Nov 13, 2007 | 08:24 PM
2004 Z06's Avatar
2004 Z06
Heres a video of one in action..
http://video.google.com/videoplay?do...34884865985766
Old Nov 13, 2007 | 08:54 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
That's the same article I remembered reading a good while back. You'd need the extra horsepower just to tote around the extra weight.
Old Nov 13, 2007 | 09:32 PM
skydive120's Avatar
skydive120
Wish I had a hair dryer right now!
Anyone have a hair dryer and some duct tape? Ha, would make for an interesting picture and deliver the same amount of power as this thing-- ZERO.
So lets see the hair dryer electric supercharger!!
One could even claim it preheats the air as to get a better air fuel mixture (I know a bunch of BS).....
Chris
Old Nov 14, 2007 | 01:08 AM
RED99's Avatar
RED99
Why not just run a hose from your A/C? At least the air would be cold.
Old Nov 14, 2007 | 01:28 PM
peebee_c5's Avatar
peebee_c5
If we run a 5.7 liter engine at 6000 rpm, that's 600cfm if my math's right:
5.7 liter x (6000rpm /2) x 1cf/28.3 liter = 604cfm.
6000/2 is for four cycle..... only pulls air every other rotation, right?
This thing is stated to be rated at 500cfm. So, at full speed, this thing would seem to just be a restriction in your intake....
Old Nov 14, 2007 | 02:23 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Flow isn't the only thing you'd have to worry about. It's the compression that makes forced induction work. The power required to compress air is significant. While and electric supercharger could work if you took a mechanical one and hooked up a high capacity electric motor to it, the electronics involved to keep it in sync with the engine and fuel system would make the unit significantly more expensive.
Air pressure at seea level is 14.7. If I've done the math correct, 6 psi (pretty conservative boost) on the engine mentioned above would generate a a boost of roughly 41%. This equates to a required flow of 846cfm in with the power to also compress the air in addition to moving it.
Old Nov 14, 2007 | 04:41 PM
Tokuzumi's Avatar
Tokuzumi
From eBay ad:
"Due to our Large Volume of Sales, Each Order will be Processed and Shipped within 5 business days after payment has been Received."
