Ignition problem?? HELP
Old Nov 12, 2007 | 04:46 AM
skydive120's Avatar
skydive120
Default Ignition problem?? HELP
Replaced my plugs and wires today with new TR6's gapped to .035 for the nitrous.
Now it hesitates and makes much less power.
Anyone else had this problem?
I checked all the connections and they are fine, plus put a timing light on it and the coils are fireing fine, thinking it could be a bad plug.
Is there an easy way to figure out which one is not fireing right, I do have an extra plug???
Any ideas--- anyone???
Chris
Old Nov 12, 2007 | 04:49 AM
skydive120's Avatar
skydive120
Forgot to mention, did have a few backfires and the plug wires are brand new.
Chris
Old Nov 12, 2007 | 05:41 AM
dougbfresh's Avatar
dougbfresh
How did it run on the old plugs?
Old Nov 12, 2007 | 04:16 PM
skydive120's Avatar
skydive120
It ran great on the old plugs, broke a few wires trying to get the boots off so I replaced everything.
Chris
Old Nov 12, 2007 | 09:58 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Backfire does indicate a miss---especially when accelerating--sounds like a broken plug - cracked insulator--or closed up gap--just curious -what shot NOS you plan to use ?? I'm using a 100 HP wet system and they recc. the TR55's at .040---It runs fine--the TR6's are awful cold with a shot of 100 or less and .035 is really narrow--But i don't know the rest of your comb. or how big a shot you have---
Old Nov 12, 2007 | 10:46 PM
skydive120's Avatar
skydive120
Most of the people I talked to reccomended the TR6's gapped at .035 as did LS1.com, does not mean its right though.
Right now the nitrous is jetted for a 75 wet shot and will be moving to a 125 eventually.
The engine runs great with no load, can not even tell is missing but with a load, going up a hill or acceleration it is hesitating and loosing power big time.
Going to pull the plugs this week and see if one is fouling up.
Thanks for the reply.
Chris
Old Nov 13, 2007 | 09:29 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
What kind of wires did you put on?
Go back to your original wires and see if that solves your problem, I switched to MSD wires once and they were awful, in the dark it looked like a light show under my hood because the wires were arcing everywhere.
Old Nov 13, 2007 | 04:07 PM
skydive120's Avatar
skydive120
The original wires are mostly destroyed now, could not get them off.
Going to check them in the dark tonight.
Chris
Old Nov 14, 2007 | 06:55 PM
skydive120's Avatar
skydive120
Checked the wires at night for any arcing and found none.
It did throw the P0300 engine misfire code today.
One weird thing is that when it starts up cold it runs great for about a minute but then starts acting funny again.
Is it possible that to cold a plug would cause this?
Chris
Old Nov 17, 2007 | 10:10 PM
skydive120's Avatar
skydive120
Finally got the problem fixed!
Put in a set of TR55's today and it runs great!!
On the TR6's it ran fine cold but as soon as the engine warmed up a bit it started missing-- plugs were simply to cold!
Chris
To Ignition problem?? HELP
