Drag radial???
Old Nov 19, 2001 | 03:53 PM
RonWhite's Avatar
RonWhite
Default Drag radial???
What is everyone using? Is Nitto going to release the 18" drags? I have an extra set of rims and need some advice.
Old Nov 19, 2001 | 04:22 PM
Brazen C5's Avatar
Brazen C5
Default Re: Drag radial??? (RonWhite)
I just recently bought 275/40/17 BFG DRs for 17" rims. IMO, I wouldnt wait for 18" DRs for the fact that you will give up sidewall flex when you go to a larger diameter rim translating to less traction. They come in the following sizes:
275/40/17 - Can use stock front 17" C5 rims.
315/35/17 - GS (or replicas) 17x11 rims are popular to mount on.
I hear Nitto's last longer, better in wet weather, but take longer to heat up and arent as "sticky."
Old Nov 19, 2001 | 05:40 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Drag radial??? (Brazen C5)
If nitto makes a drag radial in the stock size 275-40R18 then you wont loose any sidewall over 275-40R17.
Eric
Old Nov 19, 2001 | 07:17 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I think the BFG 315X35X17 are the best with a nice wide surface to grip the track. Mine are installed on GS 17X11 with the 50mm offset, just slap them on and use your original lug nuts!
[Modified by wallstAL, 3:20 PM 11/19/2001]
Old Nov 19, 2001 | 07:31 PM
J Z06's Avatar
J Z06
Default Re: Drag radial??? (wallstAL)
I tried a BFG 275/40/17 semi-worn. I smoked them off the line(track was less than perfect) but am going to try again with some 325-50-15's comparing to 26X10X16 M.T. Slicks. Lots use the BFG/Nitto with good results. Nice thing is, you can drive in, tech, adjust pressure, run, go home! Slicks or E.T. Stickies have to be chanced, PITA.
Old Nov 19, 2001 | 07:59 PM
RajunCajun2001's Avatar
RajunCajun2001
Don't wait for the 18" radials from Nitto....they're designed to fit the Ford Lightning. I'm using a pair of 335/35/17 BFG Comp T/A ZR's. They aren't drag radials, but they provide plenty of traction at the track.
Old Nov 19, 2001 | 11:48 PM
RonWhite's Avatar
RonWhite
Wallst,
Any good place for the wheels?
Old Nov 20, 2001 | 01:58 AM
intel55's Avatar
intel55
I run BFG drags on 17" rims. I recently cut three 1.6 60' times on these. They are very bald too. :D
They are cheap and they ROCK! :cheers:
Old Nov 20, 2001 | 02:10 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Yep, Blems $237.50 ea. black, chrome a little more!
http://www.AFSwheels.com
[Modified by wallstAL, 10:15 PM 11/19/2001]
To Drag radial???
