TPS Curiosity
Old Nov 12, 2007 | 06:26 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Default TPS Curiosity
I get a psi reading on one TPS that is always 6-7 lbs. low. even after changing wheels which had new sensors in them, the LF reading is still 6-7 lbs. low. any thoughts??? The reading does go up and down as the tires warm and cool. Tired of turning off the DIC notice EVERY TIME I start up. Thanks, And Dave
Old Nov 12, 2007 | 06:34 PM
khadiyev's Avatar
khadiyev
I got same problem, it's always lower, I don't know how accurate the sensors are, doesn't seem that good to me mine are about 4-5psi off
Old Nov 12, 2007 | 08:10 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Mine are always about +-1 with my gauge. Hummm
Old Nov 13, 2007 | 06:10 PM
TUF-NUF's Avatar
TUF-NUF
St. Jude Donor '13
The problem is only with the left front. All the others are very close. I wouldn't care if it wasn't accurate as I use a gauge all the time anyway...just tired of always resetting DIC. And why the same corner if the discrepancy is in the monitor? Maybe a dirty connection in the harness??? As I understand these things, relearning the TPS's won't do anything to the reading, right? thanks, Dave
Old Nov 13, 2007 | 06:18 PM
Oldvetter's Avatar
Oldvetter
Check all your tires and see if one matches the reading. Often these sensors are switched (or wheels are switched), so although you think it is the RF, it could be LF that it is actually reading.
Old Nov 13, 2007 | 06:28 PM
TUF-NUF's Avatar
TUF-NUF
St. Jude Donor '13
Checked all corners and they are all at 30 psi..... Dave (maybe I have two f**ked up sensors that just happen to be run on the left front??? Two sets of wheels with the same off-readings...
Old Nov 13, 2007 | 06:34 PM
white90conv's Avatar
white90conv
Try reprogramming them with the DIC except place the magnet on the RF wheel first and then the LF. If the readings switch, then it is the sensor. If they are the same, then it is something other than the wheel sensor.
Old Nov 14, 2007 | 06:34 PM
TUF-NUF's Avatar
TUF-NUF
St. Jude Donor '13
WHITE90; Thanks. I'll give that a try. (when it stops raining.... )
To TPS Curiosity
