Brake Pad Replacement
Old Nov 20, 2001 | 10:13 AM
Bluevette2000's Avatar
Bluevette2000
Default Brake Pad Replacement
I need to replace the front and rear pads on my 2000. Any tricks I need to look out for or things which will help make it easier. Thanks.
Old Nov 20, 2001 | 03:34 PM
Chopper Larry's Avatar
Chopper Larry
Default Re: Brake Pad Replacement (Bluevette2000)
Like most any other brake job; take care with the emergency brake stuff on the rear.
Old Nov 20, 2001 | 04:05 PM
willi's Avatar
willi
Open the bleeder to squeeze the pads rather than removing fluid from the reservoir.
You can remove just the lower bolt and swing the caliper up to replace the pads.
To Brake Pad Replacement
