Climate control panel backlighting off AUTO inop
Old Nov 19, 2007 | 11:45 AM
mowton's Avatar
mowton
Default Climate control panel backlighting for AUTO pushbutton inop
Is it readily easy to replace the led/lamp behind the AUTO push button on the HVAC Panel on the Dash? My blew out and is always dark.
Old Nov 20, 2007 | 09:11 AM
mowton's Avatar
mowton
ttt
any help?
Old Nov 20, 2007 | 11:22 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
There is a sticky on repairing your HVAC lighting. It seems it isn't the bulbs that go bad, it's the solder.
Look in the sticky on DIY, it's all right there.
Old Nov 20, 2007 | 11:27 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Its not an LED. It is normal small light bulb. However, you can buy them from GM. You have two choices, you can either replace the whole head unit or you can replace the lamps. To replace the lamps, you need some experience with a soldering iron or a friend that does. Lamps themselves, some people have found a source at RadioShack but at the time I went there, I didn't find what I was looking for. What's needed is a 70ma @ 12V lamp for the proper brightness. The lamps that I used comes with leads on it and a plastic wrap that both need to be removed, but they worked out nicely.
http://www.partsexpress.com/pe/pshow...TOKEN=71347921
I will suggest that if one has let go, that you replace all of them. Also, plan on the ones in the radio going out shortly too.
Old Nov 20, 2007 | 12:09 PM
dbirdz06's Avatar
dbirdz06
I have the exact same problem, just that one button!
To Climate control panel backlighting off AUTO inop
