Vertical Door !! Helpppp....
Old Nov 19, 2007 | 12:16 PM
Tommy/50thVette's Avatar
Tommy/50thVette
Default Vertical Door !! Helpppp....
I want pair of Vertical Door on my 03/vert...can anyboby give me advice , which is the best company to get ?
thanks alot ... 4advice..
Tommy
Old Nov 19, 2007 | 02:43 PM
chris308's Avatar
chris308
http://forums.corvetteforum.com/show...vertical+doors
Old Nov 19, 2007 | 07:57 PM
TLewis4095's Avatar
TLewis4095
I have a brand new in the box kit from vertical doors FS...$500 off. One set only!
Old Nov 20, 2007 | 08:28 AM
travelingypsye's Avatar
travelingypsye
A friend of mine has a set of lambo doors. I hav no idea what brand he has but if you do not make sure the door is completely down, you will LEAVE A MARK in the paint from the door strick when you close the door. His is so bad that he will have to have body work done to fill the holes.
Old Nov 20, 2007 | 10:49 AM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
I have the LSD system on my wifes car. Cajundude did the install. Here's his write up. http://forums.corvetteforum.com/show...t=martini+girl
I have no problems at all with rubbing. Plus you can adjust them really easy.
To Vertical Door !! Helpppp....
