LG Pro Owners, question
Old Nov 19, 2007 | 08:12 PM
happa's Avatar
happa
Default LG Pro Owners, question
Does it matter where the x-pipe goes? I have mine after the cat deletes. I seen many pics of them right after the header. Does it matter? Thanks!
Old Nov 19, 2007 | 08:14 PM
LETHL_C6's Avatar
LETHL_C6
Yours is in the right place... cats/off road then X.
Old Nov 19, 2007 | 08:36 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
check your pm's
Old Nov 19, 2007 | 09:35 PM
SpeedyZ's Avatar
SpeedyZ
LG originally recommended the X-pipe in front of the cats, and there is a slight performance gain to that setup. But if you are running rear O2 sensors you must have the cats up front. Either way seems to work well, may people have them both ways.
Old Nov 19, 2007 | 09:47 PM
Higgs Boson's Avatar
Higgs Boson
Cats up front makes them more effective at cleaning the exhaust. Cats out back make another couple HP. Keep them up front.
Old Nov 19, 2007 | 09:57 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
Cats will not get hot enough in the rear. I saw a dyno with and w/o cats on a 500 rwhp car. The cats cost about 6-7 hp if I remember right so the performance gain is negligible. LG recommended the X-pipe go after the headers unless you were running cats. If you are not running cats the proper placement is dependent upon where the exhaust starts to cool. The old way of doing it was to mark the pipes with a crayon or wax and where it stopped melting was where your collectors extensions ended and your X-pipe was installed. Mine are in front of the X-pipe.
Old Nov 19, 2007 | 11:39 PM
happa's Avatar
happa
Im not running cats, so I should have my delete pipes after the x-pipe? I had already welded the x-pipe to the back 2 pipes. Looks like I need to do some cutting and re-welding. CRAP!!! I jumpd the gun big time. dont dog me too bad fellas. Thanks for the info!
Old Nov 19, 2007 | 11:47 PM
Vette Ed's Avatar
Vette Ed
pic attached
Old Nov 20, 2007 | 12:56 AM
Higgs Boson
Originally Posted by Vette Ed
pic attached
"How To: Render your Cats Ineffective"
Old Nov 20, 2007 | 11:42 AM
Millenium Z06
Moderator
No lite off at all, you could probably handle them with bare hands in that position. And yes, with no cats I would have put the x-pipe right after the headers.
Old Nov 20, 2007 | 11:58 AM
SpeedyZ's Avatar
SpeedyZ
Without cats it will make VERY VERY VERY little difference where you put the X-pipe, you are only talking 12", but I would put if up front if I was running without cats. But mine is in the back since I'm running cats.
Old Nov 20, 2007 | 12:06 PM
Blue Angel's Avatar
Blue Angel
Old Nov 20, 2007 | 12:15 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi happa -
When I had Sean and LG install my pros - he put them on with the X pipe and then the off-road pipes.
best regards -
mqqn
Old Nov 20, 2007 | 12:29 PM
Millenium Z06
Moderator
Thats not true, the further back in the exhaust the cooler the exhaust is and the lower the velocity gets. The X-pipes design is to help with scavenging of the cylinders. This Works most effectively when you have velocity to help suck the exhaust out of the cylinders, thats what the x-pipe is for. Placing it further away from the heat source reduces the velocity of the exhaust thus reducing the effectiveness of the x-pipe. This is where the wax or crayon trick I mentioned earlier comes into play. The hotter the gases, the faster they will be moving thru the pipe. This speed is what pulls the exhaust gas out of the cylinder.
Old Nov 20, 2007 | 02:04 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Default Let's put this issue into perspective
Maybe it does make a difference where it is located.But I am not so sure it is that much to even be concerned about.
How much difference could this possibly make?1-2-3-5-10-20 hp????
Pick a number here and we will then be able to decide whether or not,in each individuals perspective, it is of any REAL significance to each person.
This seems like a good place to start this discussion to me.
Old Nov 20, 2007 | 08:36 PM
Millenium Z06
Moderator
I would guess 10-15fwhp, since thats roughly what the part is worth in the 1st place. Placing it further back where cooled gases are flowing would negate the scavenging effect that it has due to the loss of velocity by the now cool exhaust which would be essentially like it wasn't there.
Old Nov 21, 2007 | 05:32 PM
happa's Avatar
happa
Thanks everyone for the help!
To LG Pro Owners, question
Old Nov 21, 2007 | 06:25 PM
LETHL_C6's Avatar
LETHL_C6
Interesting..... FWIW, LG's site shows cats/cat delete then X on their example pic of the Pros.
Old Nov 22, 2007 | 08:35 AM
RWE 427's Avatar
RWE 427
Veteran: Marine Corps
My own personal experience for those that have to pass emissions. I put the x-pipe first then cats I failed emissions test. Moved the cats up front then x-pipe I passed. Cats don't light off in the rear position. If your not running cats then I would put the x-pipe first then the off road pipes.
Old Nov 22, 2007 | 10:22 AM
slow ride's Avatar
slow ride
Does anyone have any comments on how much the cats quiet the car down? I've had cats in since I've had the car and was curious how loud it would get without them. The slip fit makes it a pain to swap out the cats.
