Do I pull motor from top or bottom???
Old Nov 20, 2007 | 11:59 AM
kaizenz06's Avatar
kaizenz06
Default Do I pull motor from top or bottom???
I don't have a lift and will be doing this with jackstands in my garage. My info will be helpful. THanks!@
Old Nov 20, 2007 | 12:06 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
If you dont have a lift, you have to pull it from the top.
Thats the only way I do it. Its actually quite easy.
Here is one of the best tutorials you will find. Compliments of CF member/vendor "Cajundude"
http://www.cajundude.com/engineswap.htm
Old Nov 20, 2007 | 12:10 PM
fsuforever's Avatar
fsuforever
Yep i would agree ,i would pull it from the top also
Old Nov 20, 2007 | 12:22 PM
MattB's Avatar
MattB
I'm going to try it out of the bottom in a couple of weeks. Did it out the top over the summer and it seemed harder than necessary, kind of made me feel like it was designed to go out the bottom. I think with some 6 ton jackstands (just a guess, but I was thinking about 20 inches off the ground) it can be done.
Hopefully I'll have some photos to show in a month of so...
Old Nov 21, 2007 | 01:16 AM
kaizenz06's Avatar
kaizenz06
Did you guys leave the tranny in the car still? Thats my plan. Thanks!
Old Nov 21, 2007 | 01:24 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Yes, You unbolt it at the bell housing.
Old Nov 21, 2007 | 01:26 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
You'd better get it higher than 20" off the ground. The motor wont even clear the bottom of the car. And thats if its laying on the ground.
Old Nov 23, 2007 | 03:51 PM
Just Enough's Avatar
Just Enough
kaizenz06,
Your PM mailbox is full, I tried to PM you that the 921 springs you were asking about are available.
Thanks, John
Livermore, CA
Old Nov 23, 2007 | 04:07 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
Out the top for sure. Took me and 2 buddies from 10 am to 5 pm to go from running to new engine running and that included putting headers on at the same time(it had stock manifolds) jack stands and a cherry picker and your good to go
To Do I pull motor from top or bottom???
