LapTrax Input
Old Nov 20, 2007 | 12:00 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Default LapTrax Input
I installed the Laptrax last week and it worked fine during the day. At night when the head lights are turned on it reverts back to " trac/active handling on" mode. If I flick on the high beams it goes back to "comp mode". It gets its power from the yellow wire in the accessory power connector. It appears that the sudden drain in power when turning on the lights activates the LapTrax. The Battery is fully charged and all +electrical connections and grounds appear to be clean. Has anyone had this problem?
Old Nov 20, 2007 | 12:03 PM
Mike Mercury's Avatar
Mike Mercury
I remember reading that the original power-wire connect location was not the cleanest (DC wise); and that Mike had a solution for this. Best to contact them to get the details. I imagine it's a simple fix.
Blue Angel's Avatar
Blue Angel
Old Nov 20, 2007 | 12:38 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Old Nov 20, 2007 | 02:28 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Old Nov 20, 2007 | 04:20 PM
Former Vendor
Called Mike, He said that the unit is specifically designed not to be effected by changing power loads. Unit has been sent back for repair. Problem resolved, good customer service
Old Nov 20, 2007 | 07:28 PM
Mike Mercury
I do believe there was an update early on in this products history. You must have one of the newer ones. Glad it is being taken care of,
Old Nov 21, 2007 | 02:00 AM
Dirty Howie's Avatar
Dirty Howie
I bought one 6 months ago and still haven't had it installed......
DH
Old Nov 21, 2007 | 07:13 AM
99 vett babycar's Avatar
99 vett babycar
I've had one for over a year- never any problem. Only down side is waiting for it to do its thing before you put the car in gear.
Old Nov 21, 2007 | 08:04 AM
craig04c5's Avatar
craig04c5
If you have an automatic you can't put the car in gear until the LapTrax changes modes? Do 6 speeds have any issues before starting off?
Old Nov 21, 2007 | 08:18 AM
Former Vendor
Yes,you can put it in gear but you have to wait for it to go to comp mode before moving.
Old Nov 21, 2007 | 11:52 AM
Mike Mercury
It has to do with the year of your Corvette... not the tranny type.
From 1998 thru 2000... you have to wait. From 2001 thru 2004 - no waiting required.
To LapTrax Input
