Just got the rotors/pads replaced all around on our C5 coupe and the brake place recommended that we replace the rear outer tie rods. Is this a difficult do-it-yourself job? We don't own an impact wrench, which limits the amount of torque we're able to apply in tight spaces, so if that's the case, we'll end up having to pay the brake place to do it. We do not have a service manual, and since we're considering selling the car, we aren't going to buy one at this point. Found the parts on gmpartsdirect for ~ $146. Brake place will install them both for ~ $54, but if it's a quick and easy job, I'd rather save the money. Of course, nothing is ever quick or easy when it comes to the corvette.
Search turned up squat as did tech tips section. TIA.
Go to either Fichtner Chev or Gene Culley for better pricing overall including shipping. GM Parts Direct has high shipping pricing.
For only $54 I would let the shop do it. That's a very fair price.
BE AWARE, you will need to do an alignment after. I don't care how careful the shop is in measuring lengths, etc of the new T/Rs, alignment measurements are measured in fractions of degrees and you rear toe specs are going to be affected by the new ones.
HTH
HTH
The swap is very easy. I did my LH one and it took longer to remove the wheel then to change the tie rod. I got it to where it was reasonably close and then to the alignment shop over the following weekend. No need to pay them for something you can do in less than an hour.
