engine dies
Old Nov 20, 2007 | 09:02 PM
jetmech09's Avatar
jetmech09
Default engine dies
sometimes my engine will turn off after getting off the expressway. starts right up with no other issues. what can this be?
Old Nov 20, 2007 | 09:45 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
This just happened to my '99 last week. I had just been working on splice pact 100 on top of the right forward frame rail earlier in the morning too. When I went to exit the freeway here at work, it just quit on me. While still rolling, clutch in of course, I tried to restart, but the starter wouldn't do anything. When I got it stopped on the ramp, it still refused to start until I turned off the key, back on again, and then it fired right up. On the way into work, I was stuck in a major traffic nightmare due to a 5-car pileup. I'm thinking two possibilities in my case, I may have lost the idle speed memory due to creeping along for 45 minutes to go a whole 2 miles or so or the splice pack. The following morning, the splice pack was removed and the ground wires within were soldered and connected to terminal lugs to a formal ground. The engine dying on me was the first time and so far, hasn't happened again.
Old Nov 20, 2007 | 11:31 PM
jetmech09's Avatar
jetmech09
Default engine dies
my vette will start right back up, do not have to remove key.
Old Nov 21, 2007 | 12:07 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Sounds like like "in-gear" throttle follower needs to be adjusted-Table B4317 (EFILIVE) start by taking out 10% at a time until it goes away-Can be a result of your mods--
To engine dies
