Has anyone ever swapped a manual for an automatic, or knows of someone who has? I am looking to start drag racing more seriously and the manual just isn't consistent enough. Any info on cost, problems, etc...would be appreciated.
^^It has been done. The difficulties are no so much the mechanical aspects as all the electronics involved.
I would contact Rodney at RPM ( a forum sponsor) who has done this before successfully.
If you do a search you will find some posts on this subject. Might have to look in the archives.
Personally, I don’t think it’s worth the effort. Massive electronic changes involved. Yes it has been done. I’ve seen it on this forum in the past. Keep searching using various search terms.
Buy an automatic. Keep or sell the manual car.
If you do it, PLEASE do a photo documentation of the project for fellow forum members. We can never have too much “good” information.
Hello, I did this on my '00. It caused more problems than I ever expected. A friend did most of the work. He gave me a tremendous break on labor. After the change, my steering wheel telescope fails to work and we had to add computers, add components and more than I would ever do again.
If you're utilizing the car for the track only then it might be o.k.
The only way anyone could ever tell I've swapped is by checking the VIN. The auto was built for the track. It didn't help my 0-60 time. Went from 2:73 to 3:43 gears and regret the swap.
Good luck
Good luck
I have no problems and everything works as it should.
If you are having alot of problems you must have done something wrong. I'm not sure where you live but a visit to RPM Transmission could correct all of your ills.
these cars are worth good money so you could easily sell and buy a A4
