Underdrive Pulleys C5
Old Nov 26, 2007 | 10:46 PM
FantasticPlastic's Avatar
FantasticPlastic
Default Underdrive Pulleys C5
wHAT WOULD UNDERDRIVE PULLEYS DO TO MY C5???
Old Nov 26, 2007 | 10:47 PM
MJD's Avatar
MJD
Add about 10RWHP.
Old Nov 26, 2007 | 10:49 PM
FantasticPlastic
what else needs to be done if I do this or any other nice bolt on mods --Bang 4 the Buck Items
Old Nov 26, 2007 | 11:29 PM
vincentjames501's Avatar
vincentjames501
10RWHP? I doubt that. Any other opinions?
Old Nov 26, 2007 | 11:33 PM
chevy406's Avatar
chevy406
I have always heard the 25% underdrive is more like 6-8 hp. Not a bad hp/$ if you are already changing out your balancer, but it is not worth the effort as a stand alone upgrade. You will also need a shorter serpentine belt ($30) plus a new balancer bolt ($4). Might as well replace the front seal too ($12).
Old Nov 27, 2007 | 06:58 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Actually I have heard it is anywhere from 8-12rwhp. If you are considering getting it done you may want to get a new cam and put the underdrive pulley on as free labor. They have to pull the underdrive pulley to install the cam. I have one on my car and have nothing but positive things to say about it.
Old Nov 27, 2007 | 12:45 PM
vincentjames501
Well then when I get my H/C swap I'll add that to the list. Any reputable brands to go with?
Old Nov 27, 2007 | 12:52 PM
GKE's Avatar
GKE
ASP is the one I have and it is very well made.
Old Nov 27, 2007 | 01:20 PM
BATM4N's Avatar
BATM4N
Originally Posted by vincentjames501
Any reputable PROVEN brands to go with?
Fixed it for you
Old Nov 27, 2007 | 01:32 PM
danziger's Avatar
danziger
I would like to do this mod on my Z06. I have had an ASP crank pulley on my 2000 Z28 for years with no issues. Should be the same with the Vette, correct?
Old Nov 27, 2007 | 02:54 PM
LoneStarFRC's Avatar
LoneStarFRC
ASP makes some nice products as does Powerbond. Getting the crank snout pinned while there is a good and cheap thing to do too (added insurance).
Old Nov 27, 2007 | 04:44 PM
FantasticPlastic
what cam do you have and the how much to install the cam??
Old Nov 27, 2007 | 04:51 PM
Fast one's Avatar
Fast one
What is the charging voltage at hot idle with everything on such as the heater fan, headlights, etc with an underdrive pulley?
Old Nov 27, 2007 | 06:19 PM
Pumba's Avatar
Pumba
It will cause your marginal water pump to become even more inefficient.
It will not allow your alternator to put out the amperage that GM designed it to put out at the low RPMs we see in 5th and 6th gear.
It will reduce the ability of the power steering pump to keep up with your turning demands.
IMHO - Underdrive pulley are not a well thought out idea.
Old Nov 27, 2007 | 06:57 PM
LoneStarFRC
Not experiencing any negative symptoms with my 25% underdrive Powerbond pulley.
BTW, alternators put out maximum amount at a very low rpm. That's the main reason automotive electrical systems went over to them over the previous conventional generators designs many years ago. Most, if not all, are "all in" by 1000 to 1200 rpms. Also wasn't aware we had "marginal water pumps" either.
Old Nov 27, 2007 | 07:28 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Been running a 25% underdrive Powerbond for over a year now, no cooling/charging/steering issues whatsoever.
Engineer scare tactics are always wonderful...but more useful are the hundreds of reviews from people actually using and enjoying the product.
One look at the quality differences between stock and aftermarket pulleys, and there is no doubt which one you'd want on your car.
I wouldn't bother with the effort needed to install one though, unless you are already in there for a cam swap, or your stock pulley is junk and wobbling (not uncommon).
Old Nov 27, 2007 | 07:49 PM
BATM4N's Avatar
BATM4N
Want to buy one since I'm doing a cam and heads and headers and intake manifold and LS6 ported oil pump swap
To Underdrive Pulleys C5
TLewis4095's Avatar
TLewis4095
Been doing these for years & running them on my personal cars....never an issue.
Old Nov 27, 2007 | 11:40 PM
BitViper's Avatar
BitViper
You could always get over drive pullys to compensate
Old Nov 27, 2007 | 11:45 PM
rustyguns's Avatar
rustyguns
underdrive pulley made a huge difference in my sand rail !!!! like 15 hp!
woohoo! and generator worked just fine!
