Tire pressure on track?
Old Nov 27, 2007 | 11:38 PM
vettekidc5's Avatar
vettekidc5
Default Tire pressure on track?
What should my Tire pressures be for my 6spd coupe running street tires- non runflats
on the dragstrip for better results?
Old Nov 27, 2007 | 11:40 PM
nickolbag's Avatar
nickolbag
Gonna depend on track conditions and launches. Start around 25lbs and play with it until it works.
Old Nov 27, 2007 | 11:50 PM
rustyguns's Avatar
rustyguns
don't overpressure them. they suggested that for my first track day so i put 40 lbs in them. they were like ice bricks!
changed to 28 lbs, worked perfect but the track was hot and ambient temps were around 90 degrees so tires coming off the track was around 34 lbs
the regular 30 lb recommendation from GM is a good starting point, lower it if the tires feel slippery
Old Nov 27, 2007 | 11:57 PM
nickolbag's Avatar
nickolbag
Air up the fronts to around 40lbs. Rears are another story.
Old Nov 28, 2007 | 03:22 AM
01 stock c5's Avatar
01 stock c5
Old Nov 28, 2007 | 08:08 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
To Tire pressure on track?
