column lock
Old Nov 29, 2007 | 05:53 PM
stevevin52's Avatar
stevevin52
Cruising
Default column lock
column lock does anybody know if there is a saftey alert on this problem so the dealer I bring it to will pick up the tab for the repair they said that there is only a bullitin on the problem but if there is a saftey alert then they will repair for free if someone has info could you please send me the saftey alert and I will print and bring it to the dealer thanx
Old Nov 29, 2007 | 08:22 PM
CMC1998's Avatar
CMC1998
You are kidding right ??? Go to the sticky note at the top of the Tech Forum. Put your feet up and enjoy. It will take you hours to read all the info.
Old Nov 29, 2007 | 08:57 PM
TEXHAWK0's Avatar
TEXHAWK0
Old Nov 30, 2007 | 04:04 PM
stevevin52's Avatar
stevevin52
Cruising
made an appt with a dealer it's going to be taken care of a no cost
Old Nov 30, 2007 | 04:07 PM
hotwheels57's Avatar
hotwheels57
http://forums.corvetteforum.com/show....php?t=1312929
Old Nov 30, 2007 | 04:16 PM
87SAM's Avatar
87SAM
and the nightmare is just beginning!
Do yourself a favor, using the search function, search the General and Tech C5 forums on this topic and learn all you can. After that, I’m sure you will go out and buy an after market CLB for $50 and be done with it.
To column lock
