reduced power need help!
Old Nov 29, 2007 | 08:17 PM
vette976's Avatar
vette976
Cruising
Default reduced power need help!
yesterday i got a little stupid with the water in my engine bay. Now my car runs like crap and now it doesnt go over two thousand rpm. my traction control doesnt turn on and it says reduced power. i dont know were to start. its a 2000 vette with a 402 6speed. please help.
Old Nov 29, 2007 | 08:45 PM
vette976's Avatar
vette976
Cruising
Old Nov 29, 2007 | 10:01 PM
Crabr1's Avatar
Crabr1
Go to the controls for your DIC.Hold down the option button and press the fuel button 4 times,it will give you a list of codes,wait till its all done and then hit reset,then you can scholl using option or trip to manually see your codes,don't worry about what codes are showing yet,just hold the reset down until they clear,remember there are 6-7 different ones you need to check,if you still have a problem then you will need to write down what codes are showing and get back on here and start looking and asking.Good luck.
Old Nov 29, 2007 | 10:12 PM
ISeeRed's Avatar
ISeeRed
you probably soaked down one or more of the coil packs. They sometimes crack if the car was hot before you washed it. Check spark at each plug to find it, if that is it. I have repaired cars that had this issue..(although not a Corvette) I have also had them get better after they dry out.
Old Nov 29, 2007 | 10:15 PM
427CPE's Avatar
427CPE
able to read codes in dic? Every time I get a reduced eng power tuning, I just rewrite the pcm. If you have tuning software, this is one way then once running you can diagnose if anything is "wet"
Old Nov 29, 2007 | 11:37 PM
fastvetZ06's Avatar
fastvetZ06
I did the same thing right after I bought my Z. Give it a few days to dry out and you'll probably be fine.
Old Dec 5, 2007 | 07:16 PM
c5Cruiser's Avatar
c5Cruiser
From: Corona CA - "An Armed Society is a Polite Scociety"
Check this thread out. It fixed my (same) problem.
http://forums.corvetteforum.com/showthread.php?t=896875
To reduced power need help!
