What cam do you run?
Old Nov 22, 2001 | 01:35 PM
DraftMe's Avatar
DraftMe
Default What cam do you run?
I'm thinking of buying a Competition Cams. Here are the specs:
Adv. Dur .271/.271
Dur. @ .050 .218/.218
Lift W/1.7 ratio .563/.563
Lobe Sep 114
What do you have and are you happy with it? What kind of RWHP changes did you get? :eek:
Old Nov 22, 2001 | 02:10 PM
DUKE's Avatar
DUKE
Default Re: What cam do you run? (Buckmaster)
218/224/114 lsa
[Modified by DUKE, 12:11 PM 11/22/2001]
Old Nov 22, 2001 | 02:23 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: What cam do you run? (DUKE)
226/234 112LSA :D
Old Nov 22, 2001 | 02:29 PM
Bytes U's Avatar
Bytes U
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: What cam do you run? (J-C-5)
222/230 114lsa
Old Nov 22, 2001 | 03:16 PM
Nilla Ice's Avatar
Nilla Ice
Adv. Dur .271/.271
Lobe Sep 114
I have that lobe for my exhaust valve. You should get 30ish RWHP out of that cam. That's one fast ramping **** and should lope pretty good in an A4, and only be slightly noticeable in an M6. You probably will set a misfire code on an A4. Should have good low end torque numbers too!
Old Nov 22, 2001 | 04:31 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
In the box awaiting installation, MTI B1 (.221/.221/.558/.558/114).
Old Nov 22, 2001 | 04:59 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Re: What cam do you run? (wallstAL)
wallstAl - who is doing your install and how much are they charging?
Old Nov 22, 2001 | 05:07 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: What cam do you run? (OliverM5)
Morgan wants $1200 since I did not buy the parts from them, including underdrive pulley.
Guldstrand about the same.
[Modified by wallstAL, 1:10 PM 11/22/2001]
Old Nov 22, 2001 | 05:28 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
$1200 for a cam install ??!!!! WOW. You might want to check around a bit.. it is about 1/2 that in the places I have checked for others.. Otherwise, do it yourself.. 6-8 hour job.. If memory serves me correctly, I seem to remember MTI was only about $500...
Old Nov 22, 2001 | 08:58 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Man, that's almost the same price I paid.....FOR BOTH PARTS and LABOR :lol: :lol: :lol:
Old Nov 22, 2001 | 09:04 PM
rfgoss1's Avatar
rfgoss1
Default That is robbery
I had MTI do a cam and headers for me and the labor for both was less than 1200. They charge 450 for the install on a cam package You better check someone else out. The group special at MTI for a cam is 599 plus 450. That is the cam package, not just the cam. Man, I would run from someone like that. Just my opinion. No offense to anyone.
Old Nov 23, 2001 | 02:43 AM
Steve454's Avatar
Steve454
Default Re: What cam do you run? (nevrenuf)
Would a cam of those specs work OK with the stock heads and manifolds on my Y2K 6-speed? I don't mind changing to the LS6 manifold but I can't afford to change the heads/cam/manifold at the same time.
$1200 sounds awful high to do a cam swap...
:cheers:
Old Nov 23, 2001 | 05:34 PM
bparker's Avatar
bparker
MTI B1 Cam (.221/.221/.558/.558/114)
To What cam do you run?
