I am in the middle of installing my tail lights right now and i am having a problem. I installed the harness and cut the white wire and now my brake lights dont work.
now if i hook the white wire back up, my brake lights work but the middle turn signals light up with the rest of the lights when my head lights are on. what is going on?
Cutting the white wire seperates the brake light from the turn indicators and runs them back sepereately to the rear of the car, then they can go their own seperate ways from where the new harness joins the old harness. Did you connect the two harnesses properly?
or did you cut the wrong wire? Those damn euro harnesses can be a PITA.
I cut the right wire, i have triple checked. and i dont know how i would install the harness wrong. I have wired up a ton of sterio systems and dvd/nav systems and I can't seem to get this right haha. I thought this was going to be a simple project. There must be something wrong with my harness, that is the only thing i can think of. Is there anyone out there I can mail my harness to and can look at it and fix it if something is wrong?
My harness had a short in it....if you have a multimeter you can check it out yourself
in the meantime I suppose you can just hook your old harness back up
