oil pressure gauge
Old Dec 1, 2007 | 09:37 PM
jim dodd's Avatar
jim dodd
Default oil pressure gauge
car always shows 35 lps oil pressure all the time. took it out today and pressure read 40 to 68 . i hope this means that the oil pressure switch is going bad ,does anyone else have any ideas wife said she could smell oil i couldnt no leaks or smoking from motor 98vette just turned 100,000 miles this week .
Old Dec 1, 2007 | 11:55 PM
abatewags's Avatar
abatewags
Mine reads 135 lbs all the time. Sensor? Where would that be anyway 98 vert
Old Dec 2, 2007 | 12:20 AM
jirasvet's Avatar
jirasvet
behind the intake, you have to remove the intake to get to it.
Old Dec 2, 2007 | 01:07 AM
bgreen83's Avatar
bgreen83
does it sit at 35 at idle? it will go up as your driving? when it reads high, it is gone.
mine is at like 40 psi at idle and it will go up if im at full throttle.
Old Dec 2, 2007 | 03:24 PM
jim dodd's Avatar
jim dodd
stays at 32 to 35 at idle go up at higher rpms but never did before until this week 40 was always the highs
Old Dec 2, 2007 | 05:20 PM
Oldvetter's Avatar
Oldvetter
Sounds low for a bad sensor, but here is how to check it:
Turn the ignition to on, with the engine off, if the gauge reads anything, the oil pressure sensor is bad. There should be no oil pressure with the engine not running.
Old Dec 2, 2007 | 07:17 PM
JOEY P's Avatar
JOEY P
Do a search, There is a way to replace the oil pressure sensor without taking the whole intake off....What you need to do to replace it is. Remove the windshield wipers and than remove the cover under the windshield wipers and than drill a hole with a holesaw and stick a deepwell socket with an extension to get to it....The cover will cover the hole up when you reinstall it....So you will never see the hole.....This IMHO is the best thing to do so you do not have to remove the intake.....And by the way make sure the new sending unit you buy is a product made by Standerd it seems to last the longest...I was told that the acdelco does not last.....Hope this helps.
Old Dec 2, 2007 | 07:48 PM
jim dodd's Avatar
jim dodd
thanks everyone ill check it out . if its the senser it doesnt sound hard to fix.
To oil pressure gauge
