Compare ALL that is included here, and all work is done in-house at our shop, one of the largest, best equipped shops in the State....not done in a garage or carwash stall. No re-using gaskets, valve seals, timing chain, etc. Also, we evac your AC system professionally with a computerized AC machine before opening the system, and then evac any moisture/contamination before recharging the exact amount of R134a your car requires.
This is complete, turn-key out the door:
Comp/RevXtreme custom grind 232/236 cam or any grind to .600 lift
Comp 918 springs
New valve seals
Comp Titanium retainers
Seats
Manley PR-4130 5/16 push rods
New water pump gaskets
new frnt cover gasket
New heavy duty timing chain
New frnt main seal
New crank bolt
Hi vol oil pump
New AC Delco oil filter
7 qts Mobil 1 10w30 (or other weight of choice)
Complete Dyno tune with street driveability
A/C evac & recharge
All this for $1947 plus tax C5/C6, $1847 F-body & GTO.
Call JP to schedule: 813-628-0080
How long would you need the car? I live in SC, so I would be taking time off from work to get the work done!
App 2 days as long as you get with JP and get the grind picked for what you want so we have all the parts here when your car arrives. 80 degree's here today! 813-628-0080
