My 1999 Coupe has recently developed a noise in the rear. It sounds like it is on the passenger side. It is a clicking or scrapping sound. It is definetely related to the speed of the car. It seems worse when I go around a corner, then gets quieter when I straighten out. At first I thought it may be the brakes, so I changed the rear pads since I have never changed them yet and I have 111K miles on the car. The old pads were only about 25 to 30 % worn. The other thoughts that come to mind are the CVS joint on the rear axle. The parking brake that I hardly ever use or the differential. Looking at it, I can not see anything that looks like it could be scrapping or leaking. I thought maybe someone out there has had a similar experience and would like to share their experience with a solution that I maybe able to tackle.
That is a reasonable thought. Do you think it would make it quieter? Perhaps I should just take it to a dealer and see what they think{dread the thought}. I am just concerned if I keep driving it would cause more damage.
Reason: extra character
Sounds like your axle splines need some lube and retorquing.
Pull thew rear wheels off and look at your axle splines; if they are rusty, back off your axle nuts, spray on some lube, and retorque the nuts.
The axle splines typically make a clicking noise when they are loose.
I agree that you should check the RR axel nut first as suggested above.
Also agree that @ 111,000 miles you are way past due to change out rear end fluild if you've not done so recently.
I highly recommend changing the diff fluid if it hasn't been done. I change mine every 18 - 24 months on my daily driver.
Price can vary by dealer - mine charges $89.95 + tax, etc.
Well I changed the differential fluid and additive today. I drove it about 10 miles afterwards. For the most part I did not hear any noise, although on my way home I did hear the sound once and it was right after going around some curves. If it is the limit slip sticking, I wonder how long it will take to free up? I also looked the the axle and it is almost like new. Here in Georgia, we just don't have as much of a rust problem. I do really appreciate all of the input all of you have provided. My neighbor retired from GM and he also felt that it was most likely the differential fluids and has experienced a similar situation.
Check your parking brake cable to make sure it's not rubbing the tire. This was the case for one of my friends. He was worried he had some major mechanical problem, but it turned out the parking brake cable was rubbing the inside of the wheel/tire.
Drove about 50 miles yesterday and the clicking/scraping sound still comes and goes. I pulled the rotor and checked the parking brake for anything loose in there. It is a little worn but still looks good enough to function properly. Another thought is the wheel bearings. My past experience with wheel bearings is that they tend to make noise all the time when they are going bad. Fourtunely I have my Z06 to drive or my truck. As you can tell, I am reluctant to take it to the dealer. I will let you all know when I finally get it solved.
What you're describing sounds a lot like the differential problem that you've already treated. The thing to do now is to drive into a parking lot and do a few sharp left circles and then sharp right circles. You steering wheel should be completely turned in one direction while performing these circles. This should help get the new fluid in into the differential crevices.
Also, are you certain that the differential additive was used when they changed your fluid? If they didn't use the additive, then you will see no improvement in the sound and it will most likely get worse.
I pulled the calipers and rotor yesterday. I tried to clean the parking brake area as best I could. Today when I drove it, NO NOISE!!! The only thing I could figure is that the Parking brake pads were offset a little or there was some trash stuck up in there.
