Tips on diagnosing tie-rod failure
Old Dec 3, 2007 | 05:26 PM
Boob's Avatar
Boob
Default Tips on diagnosing tie-rod failure
Recently my car's handling has gotten incredibly bad. She's very twitchy on the roads, and even when changing lanes it feels like it wants to follow the grooves.
It's on completely base suspension w/ 110K on it so obviously the shocks are in poor health.
I need to make sure I don't also need to replace tie rods while I'm into the suspension. What's a good way to tell if the tie rods are still good?
Old Dec 3, 2007 | 05:29 PM
TraceZ's Avatar
TraceZ
Do the rods themsleves go bad or is it just the ends that wear out?
Old Dec 3, 2007 | 05:57 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
Jack up the corner you suspect is the problem, grab the wheel and see if you can turn it left or right. Should be no play in it at all.
Old Dec 3, 2007 | 06:00 PM
LoneStarFRC's Avatar
LoneStarFRC
Barring outright breakage (very rare), unusual tire wear patterns and/or loose or sloppy steering feel are the most common symptoms. A competent alignment tech can check the T/Rs for excess wear.
I would take a good look at tires and/or alignment (especially caster) as suspects for "tram lining". Check the anti-roll bar end links too.
HTH
Old Dec 3, 2007 | 07:50 PM
jirasvet's Avatar
jirasvet
A tie rod end will pivot back and forth. You should be able to twist the tie
rod end back and forth at the steering knuckle. If you can see or feel play
when trying to pull the tie rod end out of the steering knuckle than it is
wore out. It is hard for me to explain, but you should not be able to
notice any up and down play where the tie rod end mounts. Most of the
time you have to wedge a pry bar between the tie rod and a fixed
place on the car and pull up or down to see if you can get any play
and most the time it is visible. So A tie rod end is like a ball and socket,
you do not want to be able to to pull the socket from the ball end that
mounts to the steering knuckle.
Since you cannot grease them more than likely the are wore out.
Old Dec 3, 2007 | 08:42 PM
corvettefrance's Avatar
corvettefrance
plus they receive all the heat of the front rotors which can dry the rubber boot
Old Dec 3, 2007 | 11:42 PM
427435's Avatar
427435
Just have your wife turn the steering wheel back and forth (just enough to take the play out of the system) while you're laying on the ground watching the tie rod ends. There should be virtually no play at the tie rod end.
Old Dec 3, 2007 | 11:50 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
My extreme mileage '99 still has the same tie-rods and they are still tight. Although it has never been to a track, its seen a whole lot of freeways at 301K miles now.
Old Dec 4, 2007 | 09:49 AM
sneakelman's Avatar
sneakelman
It makes me grin everytime I see that mileage.
Old Dec 4, 2007 | 01:07 PM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
It makes me say wow and shake my head. Talk about a testament to the longevity and durability of that car. I will be happy if mine gets half of that.
Old Dec 4, 2007 | 10:21 PM
dgrant3830's Avatar
dgrant3830
Sorry, wasn't trying to steal the thread, just pointing out at my tie-rods appear to be in good shape...so far. But, also admitting that its basically seen only freeways for like %99 of its life.
To Tips on diagnosing tie-rod failure
