transmission filter
TIA
By the way my car has about 67K miles n i havent change the tranny fluid since i got the car (about 34K miles ago)
I would pay some body that has the machine that filters and flushes the
Tranny, not only does it get the lines, it gets the torque converter.They
say if you have this done than no you do not have to change your filter
One thing to consider is that just dropping the pan and changing the
filter does not get all the contaminated fluid out that is left in the lines
and torque converter.
Actually i would do both have the pan dropped cleaned and replace the filter,
Than have them hook the machine up that flushes the complete
tanny system. Most dealers will try to tell you the machine filtering and
flushing is all you need. I am old school and still would want my filter
changed and pan cleaned.
I was told i could get both done for around $300.00.
HTH
My 2000 car, with 27k, has already had the trans ATF changed 2X.
GM says that it is a 100k mile fill, and if you don't overheat your fluid by constant racing, you really could make wiser use of the money spent. It's not like the engine where you have a combustion process burning off additives and contaminating the oil.
I had 50k miles on my fluid, when I replaced my transmission, and the fluid was just as red and clean as it was coming out of the bottle.
2 cents.
2 cents.
mickey_7106
you do not know how the car was originally driven so I would do both.
It is hared to get a good rebuilt trans without spending big bucks.
25k miles of my 50k were 'hard'. Drag racing, autocrossing, and HPDE's, not to mention mountain climbing (uphill racing).
There are much better ways to spend money, but I've said my part.
swear I have read this some where that dextron should be changed every
5yr/100k. At least that was our recommended interval.
Anyway it is his money and it is well spent if it gives him piece of mind
HTH
Slightly darkened transmission fluid, is not bad fluid, it is normal. transmission fluids are not created equal, best bet is to buy from a company that drills for oil, they keep the creme of the crop for themselves, the rest is set up for bid. Many thoughts on this, but, if you run your car normally, to a little hard, change oil in transmission pan & filter every 20'000/25,000 miles. If you have a burnt oder to your fluid, or it no longer resembles the color of ATF, wouldn't be a bad idea to exchange it. If you have friction material in the pan (Black dust/flakes, change the filter only, reuse your burnt fluid and cross your fingers, an overhaul is in your future. I hope not to many typo's but got to go. Hope this helps, as for the filter needed I'd have to look it up, but if I remember I'll get back to you on Monday.
