Tensioner Pulley
Old Dec 7, 2007 | 12:59 PM
tolk's Avatar
tolk
Default Tensioner Pulley
Is there a tensioner pulley on a C5 to remove the serpentine belt? If so, where is it?
Old Dec 7, 2007 | 01:09 PM
ICUALL's Avatar
ICUALL
Default location
Front of Engine Passenger side, need a 15 mm wrench or socket to disengage it. Push toward Drivers side to slack the belt.
Old Dec 20, 2007 | 05:15 AM
PortDawg's Avatar
PortDawg
St. Jude Donor '05
Push how? Just push and it'll move? Guess I'll have to push harder..
Old Dec 20, 2007 | 06:16 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
That is a great drawing showing the routing of the serpentine belt. I will save that one for future reference. The drawing I have is much smaller. Thanks!
Old Dec 20, 2007 | 11:59 AM
spider94r's Avatar
spider94r
Use a longer wrench and it's easy. I use a breaker bar.
Old Dec 20, 2007 | 04:19 PM
jedblanks's Avatar
jedblanks
Get a wrench or socket/ratchet that fits on the bolt going through the pulley next to the arrow and push in the direction of the arrow. Pulley will swing and release tension on the belt. You can then slide off the pulley (this is easier with a socket).
Old Dec 20, 2007 | 04:21 PM
jedblanks's Avatar
jedblanks
You can also use a "cheater" which involves putting two wrenches together by meshing the open in box end together in such a way that they lock and make one long wrench. Just be careful. The right size pipe over the end of wrench works too.
However this should not be that hard to move unless something wrong with the pulley. Not that much tension.
Old Dec 21, 2007 | 09:42 AM
tompugh's Avatar
tompugh
Is that the pulley that makes all the squealiing sounds after a few thousand miles? Did Chevy re-enigneer it to fix the bearing lubrication issues?
Old Dec 21, 2007 | 09:47 AM
Bob CTS's Avatar
Bob CTS
That one does cause the squealing as well as the one on the AC. It can be belts sometimes. As for a design change... not sure
Old Dec 21, 2007 | 10:03 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
There should also be a drawing on the fender of the engine bay showing the routing and the tensioner!
I know mine does.
Thanks,Matt
Old Dec 21, 2007 | 11:21 AM
tompugh's Avatar
tompugh
Oh, I thought that was the AC tensioner too. Guess I better take a look under my hood. TP
To Tensioner Pulley
