quick lowering question.
Old Dec 8, 2007 | 08:09 PM
Kale's Avatar
Kale
Default quick lowering question.
I actually want to raise my rear 1/2".
The car was previously leveled, but I want my rake back.
Can I just adjust the bolts without getting the wheels off the ground? (ie, ramps)
Old Dec 8, 2007 | 08:48 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Yeah, the rear is easy enough to adjust you can do it with the car on the ground.
Obviously there will be a little more tension on the adjusting bolts/nuts since the weight of the car is on it...but I've done some fine adjustments on the rear several times without jacking the car up.
Old Dec 9, 2007 | 01:57 PM
Kale's Avatar
Kale
Thanks. Hopefully I won't break anything.
Old Dec 11, 2007 | 09:23 PM
fastbluels6's Avatar
fastbluels6
St. Jude Donor '10
dont really recomend ajusting the back with the car on the ground... ive lowered alot of c5's and ur def more acurate if the car is up and the rims are off plus if the car is real low ur def going to have a hard time with it on the ground....
Old Dec 11, 2007 | 09:31 PM
jarda's Avatar
jarda
Looks good,nice height
Old Dec 11, 2007 | 11:12 PM
fastbluels6
St. Jude Donor '10
thanks i almost was rollin on the same wheels as u..hah i love those wheels.
To quick lowering question.
