Headlight install
Old Nov 23, 2001 | 09:37 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default Headlight install
After changing the headlight bulbs(all 4) I noticed tonight that the right high beam was searching the ground for roadkill. As all I did was unplug then plug. How/what did I mess up? Is it possible to put the light in crooked and cause it to be low? Thanks for burning me up . In addition, does anyone have the part number for the HID lights? :rolleyes: :rolleyes:
Old Nov 24, 2001 | 01:34 AM
Red Rage's Avatar
Red Rage
Default Re: Headlight install (acepilot)
I was taking a look at my stock headlight bulbs the other day and had the same problem. :( After taking the bulb out and replacing it, the bulb did not fit snug and caused the aim to be way off. I took the bulb out again and bent the little clips that are suppose to hold it snug in the assembly. I then replaced the bulb and everything was good again. :)
If you wish, I can give up you more details of this "5 minute turned 2 hour" project. :rolleyes:
