I have a methanol kit and I was wondering what type of windshield washer fluid is good for it?
I know the content of methanol varies with each (-30 has more than -20 degrees), but I was wondering if the windshield washer fluid has ethylene glycol (less than 10% per MSDS) if that is bad for the engine?
I do not want to run this product (prestone -34 windshield washer fluid with DE-ICER) if it is going to cause problems.
Probably because they don't understand the question -- I know I don't
oh Ok.
I have a methanol kit for the C5. I was told that i can use windshield washer fluid that is -20 or colder, since those have properties of methanol in them.
My question is, whether I can use this PRESTONE -34 De-ICER product that has methanol and ethylene glycol in it.
I want to know if the properties of ethylene glycol is bad for the engine components when it sprays in it.
Bottom line is if ETHYLENE GLYCOL at less than 10% ratio bad for the engine components?
I've never heard of such a thing but if you have the kit, I would think the manufacturer of the kit would be able to answer that question better than anyone else. Windshield washer in your engine???
All windshield washer fluid is methanol and water. Except on this case, the one I found that is about 80% methanol has the glycol in it.
The methanol kits are like running an inter cooler on turbo charged
vehicles,except no inter cooler. They help chemically cool the air intake and increase octane levels in fuel. Also the setup can be used on any
type of engine setup.
It is also like adding a 50 shot of nitrous on a supercharged car to help cool the air,
or using a so called freezer that uses CO2 to help cool down the inter cooler on FI
engine set ups
Reason: more info
You need to repost your question in the F/I forum. We all talk about meth kits in thread after thread so I recommend posting there for a much faster response.
Now to answer your question, almost all anti-freeze has ethylene glycol in it so there is no way spraying it in the engine with a meth kit will cause harm since it is used to cool the main engine passageways with coolant.
You were told wrong as for temp rating on windshield fluid, and ethylene
glycol is on the same line as propylene glycol and is bad for your engine
Here is a link for you http://www.snowperformance.net/forum...opic.php?t=525
So you are telling me that coolant that you use in your engine all day long is going to be harmful to add to the engine?
No, not for use in coolant passages and applications,but when you
are using it for internal use inside the combustion chamber it is a whole
new ball game. I know if anti freeze gets mixed into the engine oil
it will become corrosive and eats away at your main bearings.
Is ETHYLENE GLYCOL the same as Propylene Glycol? The prestone product I have does not have propylene glycol.
What he is saying is that it isn't good to ingest it into the intake tract. Yes there is a lot of glycol in your engine, but it isn't going in with the air....
Ahhh very true, didn't give that a lot of thought. GM has massive corrosion issues in many of their cars from this very issue. I stand corrected, sir
It is to help cool the engine. Don't need nitrous it already has over 700RWHP on it....
Dude, just post up on the FI forum. It's obvious that those responding to this thread don't have a freaking clue what you're talking about. I'm considering running meth on my vortech setup for next year, so I'm curious too. I'll look for you on the FI forum.
Use window washer fluid in the radiator..........give me a break
Where did this come from?
I know what he is talking about
