which is better
Old Dec 11, 2007 | 12:44 PM
11sec_C5Z51's Avatar
11sec_C5Z51
Default which is better
which will lower the car the most in the front.
removing the front bolts all together or installing longer front bolts?
Old Dec 11, 2007 | 06:57 PM
BanditDude's Avatar
BanditDude
The front lower a-arms press upward against the bushings on the end of the adjustment bolts. Lowering the car is done by retracting the bolts into the spring. Cutting the bushings would get it even lower, and removing the bolts is as low as you can go without coil-overs.
Longer bolts can be used in the rear, as that spring is pulled upward by the lower a-arms.
