Battery side / top Posts
Old Dec 13, 2007 | 08:58 AM
DTV's Avatar
DTV
Default Battery side / top Posts
Have anyone change their side post battery cables to top post cables?
The reason, I now had a hole eaten at the Neg Battery side post.
The hole is where the cable attach into the battery. I found it after
I saw some corrosion build up on the battery Neg post.
Took the cable off and found a hole. The pos side is still seal.
The battery look like it double wall, so I don't think it will hurt any thing.
And the hole is cover up when the cable is attact.
It a after market AMG battery.
Old Dec 13, 2007 | 09:17 AM
lucky131969's Avatar
lucky131969
I certainly don't see a clear cut advantage converting to a top post battery. The corrosion did not accumulate overnight. A little preventative maintenace would have prevented this. The Delco batterys have a history of leaking on C5's, so you really have to be watchful.
Old Dec 13, 2007 | 09:39 AM
mike348's Avatar
mike348
my 04 has top post. Might be able to find some on the auction site.
Old Dec 13, 2007 | 09:41 AM
lucky131969
Originally Posted by 8VETTE7
Apparently GM did as the 04 and up cars have top post batterys
You are right, in other GM models as well. I guess I'm just one of those weirdos who spends just as much time cleaning under the hood, as I do the outside of the car.
This is not a new issue with regard the the side post in C5's; however, I've had Delco batteries in two GM cars, and one truck (years from 97-2002) and never experienced an single problem. That being said, I've not heard of good non-Delco battery having this sidepost leak problem.
Anyone experienced this with an aftermarket battery?
Old Dec 13, 2007 | 12:44 PM
DTV's Avatar
DTV
I was just thinking about changing to top post if others has problems.
I was just a mis on my part. The corrosion was so small it was hard to see. It just the corrosion ate a hole in the battey terminal connector is the problem and wonder if any one else had this problem, before I start changing cables and replacing a battery.
I did stop at a the dealer today talked to a service person and tech and they do no recomend changing cables at all.
Tech said just get a good AMG battery. What I had happen is not normal, and do not tork the cabels to much or you could punch a hole in some batteries.
Driving back to work that neg cable was real hard to unbolt.
The Pos side was easy compar to the Neg side.
Old Dec 13, 2007 | 02:17 PM
hotwheels57's Avatar
hotwheels57
...your cable(s) may already be damaged with corrosion however.
To Battery side / top Posts
