cam/heads pkg
Old Dec 14, 2007 | 10:16 PM
jaygood's Avatar
jaygood
Default cam/heads pkg
I have a 2000 A4 w/3:15s. What would be a good suggestion on a cam/heads pkg? I want a mild cam, when I say mild I mean, I don't want it to be real radical sounding. Help
My plan is:
LG Pros
Vararam
cam?
heads?
Old Dec 14, 2007 | 10:26 PM
BATM4N's Avatar
BATM4N
Cam: 224/228 .581 114+1
Heads: Still gathering data on this but the AFR 205's seem to be a no brainer but not cheap.
Just my .02
Old Dec 14, 2007 | 11:14 PM
NASAblue's Avatar
NASAblue
ls1 tech . com cam thread......
lots of good used small port and bore heads floating around w/ all the newer larger bores on the market.
decide on goals application budget and go from there
Old Dec 15, 2007 | 08:07 AM
9secondflat's Avatar
9secondflat
what you want is the LPE 219 cam, little to no lope, pulls like crazy to 6k. he puts it in his top end packages and his 383's. i dont care for a car that shakes like crazy at idle...needs to idle at 1000+ to stay alive, my lpe 383 idles at 750-800 with out a hickcup. it is too easy to overcam a engine and you loose the fun factor of the car.
call lpe and speak with kevin 260 724 2552
Old Dec 15, 2007 | 06:22 PM
jaygood's Avatar
jaygood
Thanks anyone else?
Old Dec 15, 2007 | 06:55 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Depends on your budget on the heads--an exceptional set will cost around $2400--As mentioned the AFR 205's is a good choice for a mild set--but may be still an overkill if you want longevity and a mild set-up-I would think a set of new LS6 heads would be just perfect for a mild cam(It's what I run on my 390 RWHP A4) & they worked out great---for a good choice on the cam --I agree with the other suggestion--somewhere in the .220-.224 range @ 50 is good--lift isn't important but i'd keep it less than .550---LSA IS important--nothing lower than a 114 for a nice idle and a smooth TQ curve ( mine is a .221/.221 @50--lift is .550 and LSA is 114- mine idles smooth at 750 and passes calif emissions to boot !!!
Old Dec 15, 2007 | 07:08 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I had all the bolt ons , stock LS1 heads and the TR224 on a 114. It's a wonderful cam which passed emmission inspection ( tail pipe ) in both NY and VA.
No down side to the set up and put down 370 RWHP which is about stock numbers for the 2002-2005 ZO6.
Honestly, you had to listen to the motor good to tell it was camed
Either way you go, you'll have to change your converter first
To cam/heads pkg
