Headlight Problem
Old Dec 15, 2007 | 01:49 PM
SCPDLARRY's Avatar
SCPDLARRY
Default Headlight Problem
I'm having a problem with one of the headlights on my 2000 Coupe.
The light goes up and down ok, but after it goes down it makes a very loud grinding/groaning noise. Has anyone had this problem?
Is it easy to replace the motor or just the gears on the headlight assembly?
Old Dec 15, 2007 | 02:15 PM
pianoman011's Avatar
pianoman011
Default Problem
This is a common problem with our cars. In the general section of the C5 Forum there is a sticky on how to correct this problem. You will need to get the brass gears for the headlight motors and rebuild the units. I have done this and it is not really that difficult. But read the sticky in that forum and it will answer a lot of known problems.
Old Dec 15, 2007 | 04:21 PM
SCPDLARRY's Avatar
SCPDLARRY
Thanks PIANOMAN011. The fix looks simple enough. I'll order the brass gear and give it a try.
To Headlight Problem
