97 Vette Cranking Problem
Old Dec 15, 2007 | 10:03 PM
BIGTIRE187's Avatar
BIGTIRE187
Cruising
Default 97 Vette Cranking Problem
I Just Purchased A 97 Vette With A Auto Trans With 65k Miles On It I Love The Car And Have Ordered Alot Of Up Grades For It But As Of Right Not When Craking The Car It Spins Over Alot Before It Cranks Can Someone Help Me With This Problem Please
Old Dec 16, 2007 | 02:45 PM
timemender's Avatar
timemender
ttt
Here’s a To The Top for ‘ya –
Your post is a little confusing. Most people would consider “spins over” and “cranks” to be the same thing.
You need to elaborate. Research how to “pull codes” through your cars DIC, then post what you find. May help someone to diagnose.
Old Dec 16, 2007 | 04:12 PM
BIGTIRE187's Avatar
BIGTIRE187
Cruising
Originally Posted by timemender
ttt
THANKS THE CAR JUST SPINS OVER FOR ABOUT 30 TO 45 SECONDS BEFORE IT CRANKS UP WILL IT HAVE ANY CODES EVEN IF THE CHECK ENGINE LIGHT IS NOT ON
Old Dec 16, 2007 | 05:40 PM
Oldvetter's Avatar
Oldvetter
Check your battery voltage (with engine off), is it over 11.5 volts? If not your battery needs charged or replaced.
Is it turning over slowly? If so you should check all electrical connetions at battery and at starter. If these are okay, you may have a bad starter.
Does car run okay once started? If not, you should check your fuel pressure, you may have a bad fuel pump and/or clogged fuel filter.
The LS1 engine usually starts right up, quickly. Even when my battery was bad, it would start up on almost the first crank.
And yes, you need to pull your codes. You CAN have codes without a "service engine light" on. Even your history codes might tell you what is happening.
Old Dec 16, 2007 | 06:02 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree...my '99, just a touch on the key in the start position and its running right now.
Old Dec 16, 2007 | 06:31 PM
BIGTIRE187's Avatar
BIGTIRE187
Cruising
Thanks Guys I Just Purchased The Car It Runs Great Once Its Started It Turns Over Fast And The Battery Volts Are Fine Ill Pullcodes On It Next And Replaced The Fuel Filter Because Im Not Sure Of The History Of The Car But Its Real Clean Thanks For Your Help
To 97 Vette Cranking Problem
