Rod Bolt Question
Here is link.
http://www.katechengines.com/street_...etail.php?id=5
I'll be doing this with my bro on my car this winter!
I did this. I did it on a lift at my friend's warehouse. We built a frame around the car while it was on the lift with metal shelving he uses for storing pallets of batteries. I lashed the engine to the frame from above. I dropped the front cradle and removed the oil pan. Once in there I followed ARP's recommended procedure and torque sequence.
I used the ARP Pro's. However, I would recommend going with the Katech's. They are the same weight and length as the stock bolts but are much stronger and they are designed so you don't have to resize the rods. I didn't resize my rods as many other's haven't using the ARP's, but the Katech's don't recommend it. Also, the right way to install the ARP's would be to use a bolt stretch gauge. Katech recommends a torque value.
One word of caution. My rods didn't have ferrul's installed. The earlier one's don't, but they changed them around 99 so when you do this make certain you have ferruls or not. If so they need to be removed before installing the new bolts.
I might end up doing this myself in the future being that mine is a '98!
Q: Anything I need to be on the look out for being that mine is a '98 and a tight strong one at that?
All and any suggestions needed and welcome!
Thanks,Matt
madmatt9471, that link does not work do you have another? Or does anyone have a write up on this? Can it be done on jack stands?
John, the ferruls are small round cylinder-like inserts that go in the bolt hole on the rod. I think that when GM changed to the higher strength rod bolts they started putting these in to help. If you have a 98 You don't have them. I have a 99 and didn't. There was a thread on another board where the poster had the ferruls and didn't change them when he changed the rod bolts and lost a rod and the bottom end.
Here is another solution.
Also, the way I did it was to go down to the local hardware store and purchase two pieces of aircraft quality 3/16" stainless steel cable. With hooks on one end to attach to the motor mounts and then loop around the shock towers and double clamp. Then removed the engine cradle while on a lift. Worked perfectly and only cost me about $30.
I'll bet you could do it this way on jack stands. It won't be easy. There are some on another site that have done it on F-Bodies.
Here is a link to a write up on jack stands, but it's with an F-Body. However, except for certain differences it pretty much will translate to a Y-Body.
Rod bolt change on jack stands
As far as ferrules, here is a link to some further inof on this.
Ferrule info
You could also do a search on that site for the info. BTW, I'm not trying to promote that site on this one. It's just easier to post the links than to copy all the info and post it here.
