Got new injectors, need flow test pressure?
Old Dec 19, 2007 | 01:19 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Got new injectors, need flow test pressure?
I just got a set of 42# SVO green top injectors. My tuner will have to make a new fuel map for them and mentioned that they may be flowed at 32psi instead of the normal 42psi to arrive at the 42# rating. Does anyone know anything about this or know for sure what psi they are flowed at? Thanks
Cajun
Old Dec 19, 2007 | 02:19 PM
thetorch's Avatar
thetorch
Cajun
Here you go, from a very reputable source:
http://www.witchhunter.com/flowdatapix/b0280150558.jpg
440cc/min @ 3 bar
or
41.904761904761905 lbs/hr at 3 Bar
At 4 bar they would flow 48.387451132082916 lb/hr
Old Dec 19, 2007 | 04:25 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Injectors are normally rated at 43psi.
Vettes run @ 58psi fuel pressure though. 42# injectors in a C5 is actually flowing about 48#/hr.
To Got new injectors, need flow test pressure?
