MOTON Motorsports Now Available!!!
A step above even the MOTON Clubsports bowmanized is proud to announce the MOTON Motorsports. This is THE ultimate shock. 2 way 3 way and 4 way adjustables available.
Moton 4 Way Adjustable Corvette and Camaro Motorsport Dampers
The low speed bump and rebound adjusters are very effective in helping to control body roll while adding to turn in and is effective in controlling pitch and squat.
Features:
Separate low and high speed bump adjustment
Separate low and high speed rebound adjustment
Each adjustment done to the damper is very noticeable to the driver.
Designed to perform at low speeds as well as high speed velocities
Swivel banjo's connect the canister to the damper body
Damper bodies are produced from the highest quality steel or aluminium
Shafts are induction hardened and chrome plated
Canister pressure can be varied between 6-20 bar (100-350 PSI)
Struts and dampers can be custom built to suit your requirements - Call
Damper Sets Include: 4 dampers and all spring hardware (excluding springs)
Price is $1295 per corner for the 2 way Motorsports
Price is $995 per corner for the 2 way Clubsports
