What else should I do when replacing shocks?
Old Dec 21, 2007 | 12:17 AM
BrianG01's Avatar
BrianG01
Default What else should I do when replacing shocks?
Just put in an order with GM parts house for:
metal stabilizer bar end links
front stabilizer bar bushings
c6 z06 shocks
fuel filter
Anything else you would replace or service while you are in there?
Old Dec 21, 2007 | 06:49 AM
BrianG01's Avatar
BrianG01
good morning bump
Old Dec 21, 2007 | 07:18 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
your going to love how he car handles when your done.
Are you going to replace your sway bars and the links or just the links?
Old Dec 21, 2007 | 07:29 AM
BrianG01's Avatar
BrianG01
keeping the stock z51 sway bars. The links are getting replaced to try and get rid of a mystery suspension noise I keep hearing
Old Dec 21, 2007 | 08:28 AM
phils C5 vette
might want to make sure all the bolts in the tunnel plate are still in also.
Old Dec 21, 2007 | 09:41 AM
jedblanks's Avatar
jedblanks
Lube all the bushings you can see.
Even if you don't take them out, you can use a spray can white grease from wal-mart.
Old Dec 21, 2007 | 10:06 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
c6 z06 shocks
fuel filter
Yes! I'd do the brake lines take 'em from the plastic ones to the braided metal ones!
Thanks,Matt
To What else should I do when replacing shocks?
