Which tool for fuel filter removal?
Old Dec 24, 2007 | 11:37 PM
BrianG01's Avatar
BrianG01
Default Which tool for fuel filter removal?
Looking at the advance auto parts website they have a few different sized tools like 1/2in, 5/8in, 3/4in, 7/8in, 5/16in and then they have ones without size distinctions and are simply called "Fuel line disconnect tools"
Old Dec 24, 2007 | 11:38 PM
BrianG01's Avatar
BrianG01
http://www.partsamerica.com/product_...pbi/648722.jpg
there is the universal sizeless one
http://www.partsamerica.com/product_...pbi/647005.jpg
there is one of the ones with a size attached to it
Old Dec 25, 2007 | 07:46 AM
c3andc5's Avatar
c3andc5
My 2000 required the 5/8 size. Most of the fuel line wrenches come with a different size on either end.
Old Dec 25, 2007 | 10:17 AM
ericdwong's Avatar
ericdwong
Your profile says 1999, I know the fuel filters changed at some point but on my 98 besides the 10 MM wrench to undo the bracket, I pulled off the fittings with my bare hands. They're just press and release.
Old Dec 25, 2007 | 12:09 PM
BrianG01's Avatar
BrianG01
Im going to try that way first... 9 times out of 10 when they call for a special tool to do something you can usually do it with a hammer, a set of pliers, and an IQ above 50. I'll be damned if I dont have 2 of those.
Old Dec 25, 2007 | 12:35 PM
lucky131969's Avatar
lucky131969
Well you can certainly hammer your fuel filter off if you wish, but as a fellow 99 C5 owner, I can tell you the correct tool is required to remove the forward (to the engine) disconnect on the fuel filter. I believe the tool was under ten dollars.
A surgeon has an IQ about 50, and could perform surgery with a steak knife, but a scalpel is the correct instrument.
Old Dec 25, 2007 | 12:54 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Like stated above here you can get one of these!
I removed my fuel filter lines, fuel pump lines and the two ('98 Vette) on my fuel rail with a PLASTIC one my buddy bought at Pep Boys for cheap!
Each side is a different size so all you have to do is slip it in and turn it slightly to disengage the prongs and pop it free!
Thanks,Matt
Old Dec 25, 2007 | 01:38 PM
ericdwong's Avatar
ericdwong
OK in that case the 99's must have changed from the 98's.
To Which tool for fuel filter removal?
