Gas Smell
Old Dec 25, 2007 | 06:52 PM
rando's Avatar
rando
Default Gas Smell
I started getting an odor of gas in the cockpit while driving and also coming from the rear of my car when I shut the car off. Does anyone know what can be causing this and what's the fix?
Rando
Old Dec 25, 2007 | 07:01 PM
lucky131969's Avatar
lucky131969
Rando
Start looking around, let your nose be your guide. Look for drops on the ground. Sniff around the engine bay. Could be anything associated with the fuel system i.e. Fuel tank, sending unit, hoses, fuel filter, fuel rail, injectors, etc.
Can't determine the fix, until you find the problem.
Old Jan 12, 2008 | 02:29 PM
towertorchy's Avatar
towertorchy
1st Gear
what was the problem with the gas smell? it sounds like the same problem i have
Old Jan 13, 2008 | 12:05 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Mine always smells right after a fill up. Even if I don't top it all the way up. Never been able to figure out why.
Old Jan 13, 2008 | 03:59 PM
vincentjames501's Avatar
vincentjames501
Any codes by any chance?
Old Jan 13, 2008 | 05:35 PM
Oldvetter's Avatar
Oldvetter
My bet is on a fuel filter, under driver's side, rear (ahead of gas tank), near frame rail. Mine leaked. It is over the exhaust pipe, so I would look sooner than later (unless you have REAL GOOD insurance).
Old Jan 17, 2008 | 04:12 PM
Mark-44's Avatar
Mark-44
Happened to my '97... fuel filter seal, gasoline pouring on left exhaust-pipe.
To Gas Smell
