I just about want to jump off a cliff at this point. I had heard that the popping noise I heard while turning the wheel (standing still or while driving) at certain points could be fixed by either the front swaybar bushings or new metal endlinks. I buy both of these as well as some c6 z06 shocks and not only do I still have the steering noise, I have more suspension noises all around!
Could it be a tie rod? Im running on no sleep and looking for an answer and how much of a pain it would be to fix...
If it helps, I can feel the popping/clunking through the whheel as well as hearing it
If it makes the noise standing still while turning the wheel, it sounds like you need to be underneath the car while someone turns the wheel so you can isolate the sound. Sound travels, so you've got to be close.
I VOTE INNER TIE RODS AND WORN BALLJOINTS..OEM BALLJOINTS SUCK!
any idea what a shop would charge for this work? At this point im tired of working on the car and running out of free time
i had one balljoint replaced for 150 bucks labor. i bought the press and doing th others myself. i wanted to see how it was done
ball joint was "DANA" heavy duty 90 bucks. looked a lot stronger than the stock one. I am till shopping for inner tie rods, they make heavy duty ones 75 bucks each or stock are around 45 each.
when you see a picture of the inner tie rods you will understand why they fail...tiny!
depends on how you do it for cost...replace all the a-arms with new balljoints..$$ but less labor...or replace individual ball joints less $$ but more labor
then you need a 4 wheel alignment
if you do it yourself you will save enough money to buy all the tools,parts and have $ left over compared to having a shop do it
how hard is the tie rod replacement once the rack is out? Ive removed the rack once before for a cam install ... does it have to be completely out of the car or can you just have it hanging out of a wheel well?
I have the answer. Replace the steering rack assembly I had that problem last week. Checked everything!!!!! The sound comes from the rack. You can pick up used ones like I did. Goood Luck.
not a bad idea..i am contemplating this..i see them for around 225 rebuilt and they have new inner tie rods
so a low mileage rack around $150 with a few tie rods would make my day!
