so do I use the exhaust manifold sensors and add the extensions. Or do I use the rear sensors of the old system.
The sensors are the same. When I did LG Streets on my kids FRC they cam with O2 sims from LG. Use the extensions to extent the harness from to old front sensor location the the new location on the Streets.
Thanks for the replies...
Still confused though.
Possibly because a '04 is different?
I have 4 original sensors (2 front and 2 rear)
The headers have 2 fittings. Then there are 2 on the tubes before the headers.
I guess I will using the header fittings for the sensors and plug the 2 on the tubes in front of the x pipe and have the tuner take them off the computer
Now for the question..Which sensor do I use? The one that was from the manifold (the short wired ones with the LG wire extension), or the 2 longer ones which where the originally the rear sensors.
Move the rear ones to the front. Then use the extensions/adapters to plug them into where the front ones originally plugged into. Be sure not to cross them.That a common problem for guys when they install headers. You will still need O2 sims or will have to program out the rears or you will get CEL.
Yep. Sensors are the same just read for different parameters buy the PCM
Did not know that, I am now in the process of changing them out (taking my bad fronts out and putting my good rears on, I have no cats), thanks for saving me $150.
I just installed my LG LT's today and since I purchased them used, from LG I orderd what I thought were extensions for the rear sensors to move them behind the cats. What I received were adapters to move the rear sensors to the front. According to the tech at LG, the front and rear are not the same, rear heat up faster so that's a good thing.
If someone wants the adapter harnesses to switch the back to front I may have a set for sale. I think I am going to order the extensions that will allow the use of all 4 cats, but it may not be until the end of this week before I have them available.
