External temp problem
Old Dec 29, 2007 | 08:22 PM
Torpedo's Avatar
Torpedo
Default External temp problem
My external temperature was reading fine when i first got the car, but now its reading -38F all the time. Today for just a few minutes it started reading correctly, but now its back down to -38.
any ideas as to whats wrong with it? bad sensor wire? bad sensor?
Old Dec 29, 2007 | 09:57 PM
65GGvert's Avatar
65GGvert
Check the connection at the sensor. If all is well, buy a new sensor from your local dealer (should be under $20) and plug in new sensor. The whole connector and sensor can be pulled up from the top with the hood raised. It is a plastic ribbed plug pushed into a hole in the frame and can be lifted to disconnect and replace sensor, then pressed back into hole. Post what you find.
Old Dec 29, 2007 | 10:02 PM
Bob CTS's Avatar
Bob CTS
The sensor probably went bad, pretty cheap. Above is a great reference.
Old Dec 30, 2007 | 12:03 AM
Torpedo's Avatar
Torpedo
this isnt looking good. I couldnt get a picture to focus in, but ill try to post the best ones.
Basically, it looks like the connectors have disintegrated.
Old Dec 30, 2007 | 09:03 AM
65GGvert's Avatar
65GGvert
Looks like you're going to have to replace the connectors. I don't know what's available from GM, but I'd ask the parts dept. Maybe someone is parting out a Vette on the forum and could cut off the connector and send it to you.
Old Dec 31, 2007 | 12:37 PM
Torpedo's Avatar
Torpedo
Surprisingly enough to me, my local dealer had the probe and connector to wire into the harness on hand.
Temp Sensor - $12
Connector - $27
i cant believe the connector is more than twice as much as the sensor, but really im just glad they had everything in stock.
To External temp problem
