Service Vehicle soon DIC
Old Dec 31, 2007 | 03:33 PM
Redbrik33's Avatar
Redbrik33
Default Service Vehicle soon DIC
I was driving my 1997 C5 on the hight way at about 60 mph when all of a sudden the Service Vehicle Soon message appeared on my DIC. My traction Control and ABS light but came on. I Went home shut the car off turned it back on and both lights remained on as well as the message from the DIC to servece vehicle soon. Any idea?? Thanks
Old Dec 31, 2007 | 04:31 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Always start by puling the codes then research them. Good probability you will know what the source of the problem is from them.
Old Dec 31, 2007 | 04:51 PM
Redbrik33's Avatar
Redbrik33
how would i go about pulling the codes?
Old Dec 31, 2007 | 05:16 PM
Plasticfan's Avatar
Plasticfan
Try this:
http://www.stengel.net/diccodes.htm
Old Dec 31, 2007 | 05:25 PM
Redbrik33's Avatar
Redbrik33
So i have to go through every code to see if it has a C- or a H? If its a C thats my problem or once i do the automatic method its going to come up with all my C`s?
Old Dec 31, 2007 | 05:29 PM
hotwheels57's Avatar
hotwheels57
There probably isn't a C5/Z06 question that hasn't been asked and answered a thousand times on this site. The best way I've found to get technical questions answered is with research in C5 Tech forum.
Go to the C5 tech forum and click on "search this forum" (in the red banner) and use keywords to describe what you're looking for.
For example, "pulling codes from DIC" in this case. You'll find numerous pages of past discussions that will undoubtedly help you.
You might also look at your owners manual. Rudimentary as it is, it does have a wealth of information. If you don't have one, you can still buy them from a number of sources, including EBAY. Or, you can download your manual from site supporting vendor GMPARTSHOUSE...click on "downloads". They're in a PDF format.
http://www.gmpartshouse.com/
You can also check the sticky topics on the top of the C5 Tech and C5 General forums for great information that applies to anything C5/Z06.
Here is another site that provides information on codes pulled from the DIC.
http://www.corvettedoctor.com/Code_Main.html
If the two sites provided don't point you in the right direction, post back in C5 Tech. Someone will help you...
Old Dec 31, 2007 | 07:36 PM
Redbrik33's Avatar
Redbrik33
I ran the codes in my DIC all the codes that were there where marked history except P1626 (Theft Deterrent System Fuel Enable Circuit) which was h-c
Old Dec 31, 2007 | 08:07 PM
RrCoX22's Avatar
RrCoX22
if your ABS light is still on your having problems with your ABS module... although its not really necessary if live in an area without snow/slush
Old Dec 31, 2007 | 08:21 PM
Redbrik33's Avatar
Redbrik33
When i started the car up again after letting it sit for an hour or 2 it was back to normal no problems but i`ll have to drive for a little and see if it comes back i reset all the codes i`ll have my friend use the tech 2 that should come up with the problem right?
Old Dec 31, 2007 | 09:59 PM
lucky131969's Avatar
lucky131969
ABS module? not necessarily. Also, I don't drive my car in snow/slush and like having ABS.
Old Jan 1, 2008 | 07:01 AM
trussme's Avatar
trussme
Default Early warning signs...
....of a possible faulty EBCM...could be in your future. I have a large tutorial with photos on this...requires emailing...PM me your email address & I'll send it....then you'll have it, IF, this is the problem..
Old Jan 1, 2008 | 11:31 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
You'll want to understand your "H" history codes too. This will give you an idea of what intermittent problems that you've been having.
Old Jan 1, 2008 | 03:10 PM
Redbrik33's Avatar
Redbrik33
redbrik33@hotmail.com Thanks for the help guys
Old Jan 1, 2008 | 04:31 PM
Redbrik33's Avatar
Redbrik33
I just hooked it up to another computre it gave me P1571 as well as the P1621 could those codes be causing my ABS and TRAC Light to come on? bad battery? its 5 years old
Old Jan 1, 2008 | 10:09 PM
Bill Dearborn's Avatar
Bill Dearborn
I am sending you an e-mail with a PDF file detailing the diagnostics for those two codes. A code only tells you a symptom of a problem has been detected. It doesn't necessarily tell you what the problem part is. Both of your codes could be caused by poor voltage levels. Start with checking the battery condition and the wiring to the battery. Unlike later model C5s the EBTCM on your 97 is located in the rear by the diff. Check all of the wiring and grounds associated with it and make sure the contacts are making contact and are clean and free of corrosion. P1571 indicates the PCM isn't receiving the required torque signal. This could be due to poor contacts/grounds causing a low voltage signal, a problem with the battery, a problem with the EBTCM/PCM wiring, a problem with the EBTCM, or a problem with the PCM. P1626 isn't related to the TC problem but could result in a starting issue if not addressed. Your PCM is in failed enable mode as communication between the PCM and BCM have been lost. This could also be another indication that you need to check the battery condition and the connections at both battery posts for corrosion/loose grounds, etc.
Bill
Old Jan 1, 2008 | 10:58 PM
Redbrik33's Avatar
Redbrik33
Thanks for all the help!! I`ll keep u updated im going to grab a battery in the morning. Thanks again and for the email bill!
Old Jan 2, 2008 | 02:47 PM
Redbrik33's Avatar
Redbrik33
I just changed the battery i havent had a chance to take it out yet and drive it though i brought the old battery back and had them test it they said that the battery was pretty bad and needed to be changed hopfully this is my Problem!
Old Jan 3, 2008 | 02:34 PM
Redbrik33's Avatar
Redbrik33
I just took it out for about 45 mins worth of driving let the computers reset themselves, no problems with anything car was driving like normal. I did check the codes after driving i had 2 the P1571H and
U1016H. My question to you guys is does my problem still exsist? and its just a matter of time before the light comes on again? Thanks
Old Jan 3, 2008 | 02:52 PM
hotwheels57
Clear all of your codes (H & C), drive and enjoy it...periodically check the DIC for any codes.
To Service Vehicle soon DIC
