Air Pump
Old Jan 3, 2008 | 11:34 AM
emj's Avatar
emj
Default Air Pump
Am I correct in assuming the air pump can be tested by disconnecting the line (at the driver's side check valve for instance), starting the engine, and see if air is flowing?
emj
Old Jan 3, 2008 | 03:00 PM
FASST LN's Avatar
FASST LN
You can actually disconnect it at the windshield washer resevoir if that is easier.
Assuming your car is cold, then the air system should come on when you first start your car. I did this while diagnosing my P0410 problem and the air pump worked fine.
That is why I never suspected the vacuum line being the problem...but it was. The Chevy technician, using the Tech2, showed me how when he programmed in for the air pump to come on, it wouldn't. I cannot understand nor explain why it would work for me using the above procedure but not work for him while using the Tech2. Regardless, he was right in his assessment.
Old Jan 3, 2008 | 06:16 PM
emj's Avatar
emj
Thanks again for the info. I think I will test the pump, replace the rear check valve, and check the vacuum line again. I know from reading posts the rear valve is a b****. On initial glance, it looks like replacing 5' of vacuum line will be a chore also.
Old Jan 3, 2008 | 07:56 PM
FASST LN's Avatar
FASST LN
Do you have access to an air compressor?
If so, have you tried the trick with blowing some carb cleaner through the check valves a couple of times followed by blowing WD-40 through the check valve a few times? Apparently, this was worked for a lot of people and saved them from having to replace the check valves.
Old Jan 5, 2008 | 03:20 AM
Dirty Howie's Avatar
Dirty Howie
What is the problem you guys are having.
Is the check valve stuck open or closed?
I am concerned that a lean condition exists on my car and it was suggested that the valve may be letting air by.......????
DH
Old Jan 5, 2008 | 08:18 PM
RonJ's Avatar
RonJ
I filled the line with carb cleaner and let it sit. Put the air hose to it, buttoned it all back together and haven't had the CHECK ENGINE light or codes since!!
RonJ ...
To Air Pump
