TR-55 vs TR-6
Old Nov 27, 2001 | 06:46 PM
99 Corvette's Avatar
99 Corvette
Default TR-55 vs TR-6
Is either one better? What are the differences/advantages/disadvantages? TIA
Jerry
Old Nov 27, 2001 | 06:50 PM
Chris@SD's Avatar
Chris@SD
Default Re: TR-55 vs TR-6 (99 Corvette)
It is not a better or worse situation. If you are NA, the correct heat range for you would be the TR55. With forced induction such as superchargers, you will want a cooler spark plug. This is where the TR6 comes in to play.
Hope this helps,
Old Nov 27, 2001 | 07:01 PM
99 Corvette
I see people talk about "colder" plugs, but I don't quite understand what this means. Can someone tell me what makes a plug "colder" in layman terms? Thanks
Jerry
Old Nov 27, 2001 | 09:12 PM
C5Cemo's Avatar
C5Cemo
A colder plug is designed to keep the combustion process at a colder temperature than a standard heat range plug. That's why it's good to go colder for forced induction; blower, turbo or nitrous; which creates added heat that can cause damage.
Old Nov 27, 2001 | 09:50 PM
C5 Tweaker's Avatar
C5 Tweaker
A "colder" plug does not lower combustion temperature, but rather only the temperature of the center electrode. If the electrode is too cold, deposition will form and misfiring may occur. If it is too hot, detonation, rapid wear, and even catastrophic electrode failure may occur.
Simply looking at the plugs provides a tremendous amount of information supporting any possible temperature change. I am sure you can find a "how to read sparkplugs" chart on the net somewhere.
Old Nov 27, 2001 | 10:06 PM
99 Corvette
Thanks for the imput guys. I guess I will go with the TR-55s then.
Jerry
Old Nov 27, 2001 | 10:08 PM
geekracer's Avatar
geekracer
Check out this web page. It has some info on spark plug heat ranges.
http://www.ngksparkplugs.com/techinfo/spark_plugs/
See the how they work section
To TR-55 vs TR-6
