Oil Changing Tip
Old Jan 4, 2008 | 07:38 AM
SEAMOORE's Avatar
SEAMOORE
Default Oil Changing Tip
You know when changing the oil, removing the filter always makes a mess. Here is a tip I've been using for years. Take a medium size nail and with a hammer punch a hole in the center of the bottom of the oil filter. Position the catch pan and pull the nail out and let the filter drain, then remove the filter. For me, it works much better than the Walmart plastic bag trick.
Old Jan 4, 2008 | 09:18 AM
MKeller's Avatar
MKeller
Old Jan 4, 2008 | 09:23 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Never thought of that great idea. Will be doing that tomorrow. I'm at 10%.
Old Jan 4, 2008 | 09:31 AM
bighank's Avatar
bighank
Default Or you can put a screwdriver thru it and use it to turn the filter
On my old chevy impala I had an oil filter refuse to untighten. Using an oil filter wrench only succeded in causing the outer shell to collapse as I twisted it counterclockwise.
Solution:
A medium sized screwdriver right thru the filter coming out the other side. Horizontally not vertically. Then I had enough torque to twist the beast loose and finally off.
Not the cleanest job but it worked.
I now tighten all oil filters about 3/4 to 1 turn past first contact with the base.
At 1 turn it WILL COME OFF and it WON'T leak. Have oiled the street before this and thats probably why I had my filter on too tight.
BIGHANK
Old Jan 4, 2008 | 11:54 AM
JanMan99's Avatar
JanMan99
I have also done this with horizontal filters......good to not let that high priced Mobil 1 synthetic glom your face and garage floor.....
Old Feb 21, 2008 | 02:46 PM
jmmy's Avatar
jmmy
Love it. I've lost most of my religion since I've been changing that Vette. Got a feeling it's gonna help with the wife's Tahoe too.
Thanks.
Old Feb 21, 2008 | 03:35 PM
mike348's Avatar
mike348
Great idea. Thanks
Old Feb 21, 2008 | 04:48 PM
Plasticfan's Avatar
Plasticfan
I saw this tip a while back but just tried it the other day. Works great. Never too old to learn new tricks.
Old Feb 21, 2008 | 07:43 PM
SPS's Avatar
SPS
...... but crack the filter loose before you punch the hole. In case that filter decides not to come off, you still have the option of driving the car to the shop.
Old Feb 22, 2008 | 10:46 AM
curtbriggs's Avatar
curtbriggs
That's
To Oil Changing Tip
