Sylvania SilverStar bulbs
Old Jan 5, 2008 | 10:56 PM
silver97's Avatar
silver97
Default Sylvania SilverStar bulbs
Has anyone used these in their vette? Are they better than stock? Are they safe to use? How do they compare to HID? Thanks!
Old Jan 5, 2008 | 11:30 PM
Snidley's Avatar
Snidley
They are just OK. I had them for a couple of years and didn't notice much if any improvement over stock. I now have a HID set that I just got in 2 weeks before the car got put away for the winter. So far, they are just great.
Old Jan 5, 2008 | 11:48 PM
jss812's Avatar
jss812
Never had the HID but the Silverstar Ultra's are a good bit brighter and cast a white light. I started off with just the low beams and liked them well enough to get the highs as well. I've had them for a while now and haven't had any problems.
You might want to take a look at Sylvania's website. They have a light for light comparison although HID are not included. Might give you a better idea of what to expect.
One thing of interest is that after the swap, I found that my headlights were doing a wonderful job of lighting up the ditch. I never noticed that before. The "hot spot" is easier to see (and is kinda weird shaped). Anyway, I spent some time aiming the lights.
Please take this with a grain of salt since it is subjective and your mileage may vary.
Old Jan 5, 2008 | 11:53 PM
black98c5's Avatar
black98c5
Anything is better then stock. I wouldn't waste my time with aftermarket bulbs as you'll only see a slight inprovement. Best bang for the money would be some HID lighting. I myself am going with HID next month. You should check out this thread:
http://forums.corvetteforum.com/show....php?t=1899176
Old Jan 5, 2008 | 11:58 PM
moserbe's Avatar
moserbe
I've got these in the C5 and the wife's Silverado. They make a big difference over stock. Glad that I installed them.
Old Jan 6, 2008 | 03:13 AM
DefenderC5's Avatar
DefenderC5
If you are staying with stock lighting, the best bulbs I have ever used were the Phillips Vision Plus. They are a step up from the Silverstars. Very clean, sharp, white light (no crappy blue)... as good as a halogen gets IMO. No halogen compares to a HID. And no HID bulb swap compares to a true HID (projectors). It just depends on how much you want to spend... there is a huge price gap between HID bulbs and HID projectors.
Old Jan 6, 2008 | 03:15 AM
FUN LS1's Avatar
FUN LS1
St. Jude Donor '08-'09
Just bought a set, we'll see how it goes
Old Jan 6, 2008 | 07:14 AM
qwkz06's Avatar
qwkz06
I put the Ultra's in my car and did the high beam mod to the bulbs for my low beams...BIG difference. Highly suggest it.
Old Jan 6, 2008 | 07:43 AM
99 vett babycar's Avatar
99 vett babycar
I also did the high beam mod AND added a transformer to keep all 4 lights on when I go to highs - it'll light up a ballfield.
Old Jan 6, 2008 | 11:20 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Silverstars are moderatly better than stock, but IMO are still dangerous for night driving.
HIDs have far more output but in the stock reflector housings have horrible hot spots and glare esleciappy if you get the 5000K capsules. I'd go 4500 or 6000 otherwise your eyes will hurt after driving at night.
What you might consider is replaceing your fog bulbs with HIDs. this will give you a Nice sharp cutoff and eleminate the need for headlights all together.
Old Jan 6, 2008 | 12:11 PM
hattitude's Avatar
hattitude
I've been reading about the Halogen Infrared Reflecting bulbs, like the ones used in the viper.
They can be used to replace 9005 & 9006 bulbs with minor trimming. They seem to be quite a step up from stock and a lot cheaper (approx. $30/bulb) than a HID conversion.
Not convinced enough to try them yet.....
Old Jan 6, 2008 | 12:40 PM
byronhunter's Avatar
byronhunter
Default Hir
I tried Silverstars, some better than stock, but not enough. I'm running relays for full batt voltage. Ditched the Silverstars and installed the HIR bulbs, much better! HTH
Old Jan 6, 2008 | 02:59 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
If you were going to replace all 4 bulbs with HIRs, HIDs are about the same price. (no trimming required.....unless you want to build your own custom projectors like me )
Old Jan 6, 2008 | 03:19 PM
todbusa's Avatar
todbusa
I want to do this how????
Old Jan 6, 2008 | 03:24 PM
FUN LS1's Avatar
FUN LS1
pix pix pix pix
Old Jan 6, 2008 | 04:50 PM
silver97's Avatar
silver97
Default Thanks!
Sounds like the major consensus is to go HID. Will probably wait and save up for them. Saw that thread with the offer as well for $229 and sounds tempting. Thanks to all for their inputs!!!!
Old Jan 6, 2008 | 05:35 PM
nitrojunky's Avatar
nitrojunky
I like my set; better & whiter than stock, however... nothing like the HID's I've seen when driving friends' cars. Price is kinda steep at $50/set.
To Sylvania SilverStar bulbs
Old Jan 6, 2008 | 07:51 PM
99 vett babycar
I'm sorry I didn't keep the write up but it was from a post on this forum that I found when I did a search on headlights.It takes about 30 minutes and I'm pretty sure total cost was under $25.
Old Jan 6, 2008 | 08:22 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have been running a higher wattage "blue" bulb in my Trailblazer and Vette for the past 4 years. Not heat issues, nothing. Brighter and more white light.
Purchased them on Fleabay for $5 a set, shipped.
The Sylvania's are just a retail mark up, IMHO.
Old Jan 7, 2008 | 03:18 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
You will notice a difference but then you will be wondering about the next step up. When you consider that the Silverstars are probably close to $20-$25 you are 1/4th of the way to HID bulbs.
